why use a step-up converter like this ?? (confused)
  • why use a step-up converter like this ?? (confused)
    Hi, I'm still learning electronics, I have this metal detector (Seben Extreme, MD5002) very bad clone of an old commercial TR-GEB-DISC detector (don't know what was the original brand, someone saids whites).
    My question is about using this step-up converter:
    Battery pack = 12V
    linear regulator (7809) = 9V
    step up converter rise the voltage to ca.12V
    I do not understand why lower voltage from 12V (battery) with the (7809) and the rise this voltage to 12V (again) with a converter...
    I've tried to power the machine with 9V (after 7809) and it works as aspected... so why don't put 12V of the battery directly into the machine (after step-up converter) directly ???
    I know this converter are noisy... really cannot understand..
    I'm a geologist so i see things in another way, and my impression for this design, is that layers of different era and composition stack up in this badly copied circuit
    I suspect the requirement here is to provide a regulated +/-5V supply. If you run the circuit directly from a 12V battery, then you would have an input voltage that fluctuates over quite a wide range, and consequently the 5V supplies would do the same. In this case the circuit needs to regulate the incoming supply first (~12V down to 9V), then boost it to the required level (say 12V) and use a rail splitter to derive the +/-5V supplies. This makes maximum use of the battery capacity, allowing the input voltage to drop to ~10V before the 9V regulator drops out.
      ah ok, your explanation is clear, and about the noise ? do you think is safe use this converter ?
        It looks like a simple boost converter, so it should be perfectly safe.
        I assume the converter is driven by pulses from the TX oscillator (via R46) so any noise will be synchronized to the transmitter, and can easily be filtered out.
          Yes is drived by the TX oscillator, thank you.
