battery charger Help
  • battery charger Help
    Hi everyone
    I want to identify the components of this circuit (battery charger)
    What do you want to identify? Everything is clearly shown in the schematic.
      If you plan on using this as a general purpose power supply, don't. At the very least, make sure your last will and testament, and your homeowners insurance are up to date.
        The value of ziner diode?
          I plan to use it as charger for 4 cells (Li-Ion 3.4 v) in series.
            It appears to be 33volt 5 watts , but only use it with an isolation transformer thats a very dangerous circuit feeding a straight 220 volts into it, there are better circuits around
              http://katod-anod.ru/rd/d816 use google translate. I personally would use something like tp4506 lion battery charger module. They are cheap as chips https://www.youtube.com/watch?v=KoHtxZG7leQ
                If one of those Bridge Diodes takes a spike and turns wire things could get ugly touching the connector.
                  Tested and proven...for 3 batterries in series just dont include the last two..
                    Thanks for the warning
                      This is the PCB
                        li-ion sells is not charging in series.
                          thanks for this schematic I think this is safe circuit
                          what serve these Variable resistors? is it for adjust the output voltage?
                            i did buy this one. low price. remaked it for doing not insert sells, added a cable with connector.
                            http://www.ebay.com/itm/2PCS-18650-3...YAAOSwHQ9WUm~n
                              The service buying online does not exist in my country. for that reason i want to build it with my self.
