Chinese toys
  • #62
    Hi
    it looks like the igniter of a fuel boiler for house.
    • #63
      KT315 I could not get the search box to work myself.
      6666 next way... i found the kit in aliexpress (tesla+plasma), then clicked above and changed page language on mandarin.
      i got https://www.aliexpress.com/item/diy-...StoreLevelAB=0
      so you can take words after CNIKESIN DIY on mandarin and use for search.
      again, i did not find the kit on http://www.haodiy.net/index.html
      why would you buy that lol you get them out old tv`s you just need a fet and a transistor ???? i just binned 2 the other week
      • #64
        Spotted some new toy from our Chinese friends
        Hantek 1008C 8CH USB and MINI DS212 Digital Storage Oscilloscope
        • #65
          where ?
          • #66
            where ?
            https://www.banggood.com/Hantek-1008...r_warehouse=CN
            https://www.banggood.com/MINI-DS212-...r_warehouse=CN
            I just typed Oscilloscope in there search engine. A few I not seen before turned up
            • #67
              Thanks for this information, its all new to me, just spent 1/2 an hour trying to make it work
              finally figured out how to use it, you UPLOAD the .jpg then open it in google docs then translate,
              I tried pasting the .jpg but it did not like it.
              the process works and it may be very usefull for translating other picture type documents
              but in this case the translation from Chinese symbols to English was a strange mix of words that did
              not give any technical details of the diy kit,
              The circuits that I have been able to find on the site do not have enough components to match
              your component list , I am also trying to find the company contact email but its not easy
              but I will try again later today.
              Just tried the translation process on a PDF file written in Geman, and it worked about 80%
              so its readable.
              • #68
                There is a sale on 3d printers @ https://www.gearbest.com/3d-printer-_gear I saved 75% on the one I have been watching for a while now.
                • #69
                  which one did you buy ?
                  • #70
                    Flsun fl-M13 aluminum 3d
                    kit , been umand arren for some time now and though bugger it need to make a coil housing and this has the best print base for $$ use all the promo codes and you been surprised at how the prices can come down even got micro camera adaptor with it for same price thrown in. so will test it all out if it makes it here with the xmas mail rush
                    • #71
                      https://www.youtube.com/watch?v=Es0iunGPdiA
                      • #72
                        Hi Chiv
                        how is your Flsun fl-M13 aluminum 3d going, would you say it was a printer that was a good one to start with?
                        or is there something slightly better ?, does the hot bed work ok, do you use tape or glue on the hot bed ?
                        I need to buy something to start with
                        or maybe even a
                        Anet E12
                        thanks
                        • #73
                          Just for fun I've bought a DSO138, fully assembled I've got a specific purpose for it, lets see if it works,
                          Also these 3D printer kits are a pain in the neck, after watching many youtubers , they all seem to report some problem with their printers and they dont work properly out of the box , parts dont fit right or they are out of spec, or it needs another part fitted to make something better and stronger,
                          but they reported to have plenty of potential ,
                          who cares about potential ,
                          I want a kit that prints out of the box,
                          the main message I got from the video's was buy a kit that has lots of new bits that you can make to turn the printer kit into something that works properly
                          • #74
                            smaller print area than I read, but after rereading the description it was as it said, but of tricky writing or just slow brain power on my side, work a treat and for what I paid for it could not be happier, taking a bit to get it set up in the program for tolerances as tried to print through the heated table when first started and blocked the printing head once, I'm using the auto measure for the table height and micro switches for the rest of the limits, just required to flash the board for the printer, using the .04 nozzle and got layer settings on .03 seams to give the best weld and finish. the biggest dilemma I had was to work out nozzle off set to the auto measure set up, to get the first layers to weld nice, the heated table works a treat and can get hot enough for a burn, so table ended up x200mm z 200mm y200mm so can do most stuff with out cutting projects up and print and glue. some good old 100mm masken tape on table witch seam to work really good for getting the prints of the table. this kit was very easy to follow and could put it together in a few hours if you smashed it out but I only worked on it after work hours be tween gaming, frame strong as could be, cabling like every where and I could shorten it all up and look pretty but I like the random unkept look, and lots of spare bolts and nuts so did not have to worry about running out. I have printed on a 41C day no problems and printed out on a 16c day no problems had to turn heat up on the nozzle to get a better finish but worked well. I printed out a spider coil former and with the table turned of it curled so redid it with the table at 70c and it laid and stayed flat so any skinny flat projects I use the heated table reasonably hot, hope this help you 6666
                            • #75
                              Thanks Chiv that does help, I will keep investigating the kits and try and get one.
