Chinese toys
- portable 1MHz digital storage oscilloscope kit (1channel)
- spectrum analyzer
- frequency meter till 10MHz
- trigger output to synchronize with additional scopes to get 2 or multi synchronized channels scope:
https://www.amazon.com/Luxury-Oscill...eld-06204KP%2F
every vintage detector needs ESR checking of all electrolitics. you can not be out from this tester. also no way to check a mosfet by ordinary tester.
you have to see the advantages. https://twitter.com/jburdeezy/status...12564980301826
Nobody checks ESR of small voltage, cheap electrolytic capacitors in old metal detectors. They simply replace them with new ones as good best practice, including all tantalum. MOSFET transistor have predictable signs that they are compromised.
Fancy tester is luxury not necessity.
Before installing new capacitors, check each one against the other of same value for suspect defective one, it will show up as anomaly on ordinary multimeter.
if you are so mindcontrol find out a problem on this PCB http://ipic.su/img/img7/fs/CIMG6443.1550232208.jpg
somebody took being teaching me here... with experience from 15 years old in electronics. BTW i am now 57 -!!!!
Originally posted by kt315 View Postif you are so mindcontrol find out a problem on this PCB http://ipic.su/img/img7/fs/CIMG6443.1550232208.jpg
Luxury not necessarily indispensable. See?
