Originally posted by 6666
View Post
The Crossbow Classic PI
Originally posted by Qiaozhi View PostI was examining this coil for someone else who wanted to use it on a Crossbow detector. That post was from Nov 2017, and I cannot remember whether the two loops were balanced, although I suspect not.
The advantage with 00 vs DD is that the tight radii on a DD give rise to lift-off effect. Lift-off is even worse on a concentric. And the OO coil is even better than the 00 coil on lift-off; in fact, you can't get any better than a round coil.
Originally posted by surfdetector View PostYes, we need the patent number indeed,
Does this look like the correct one?
https://patentimages.storage.googlea...17015730A1.pdf
Originally posted by MartyJ1963 View PostHi Carl, I've never heard of 'Lift-off' effect, could you explain what it is please? Thanks, regards, Marty.
A DD coil does a better job, except for those tight radii along the overlap area. Again, as the coil is lowered the broad radius portion of the field is distorted first, then the field of the tight radii when even closer. However, the tight radii field is a much smaller percentage of the total IB so the effect is much less than concentric.
An 00 coil (SEF, ellipses) is even better than DD, and an OO coil (Nexus, circles) should be the best. The OO coil has a uniform radius and therefore a uniform field so there should be zero lift-off effect.
Lift-off is a term widely used in non-destructive (eddy current) testing.
Originally posted by surfdetector View PostHi Marty,
Did you ever do one of the Crossbow machines or just the Mirage? I was thinking about getting a few Crossbow boards made as the Gerber files are here.
Cheers
I am in the process of ordering 5 boards as per the files in post #18 of this thread.
Hello Martin,
I had a successful build of the Crossbow Classic and I did a series of YouTube videos of my build here that you might find to be of interest:
https://youtube.com/playlist?list=PL...25R5R4iut8Y_s1
Hiya Martin. Here are the Gerbers for the Crossbow pcbs that Alec used successfully. I don't know if the ones in post #18 are different to these but these are proven. Have a successful Build! I'll be starting a new Crossbow thread hopefully soon. George has kindly given me his consent to write a Crossbow Build Guide that he will review for me before I ask his permission to post it. It will be in accordance with a lot of information from Alec's top class videos and photo's etc that I will be taking as I build along to add to the guide. Hopefully it won't take too long!,,Lol Regards, Marty.Attached Files
Originally posted by MartyJ1963 View PostHiya Martin. Here are the Gerbers for the Crossbow pcbs that Alec used successfully. I don't know if the ones in post #18 are different to these but these are proven. Have a successful Build! I'll be starting a new Crossbow thread hopefully soon. George has kindly given me his consent to write a Crossbow Build Guide that he will review for me before I ask his permission to post it. It will be in accordance with a lot of information from Alec's top class videos and photo's etc that I will be taking as I build along to add to the guide. Hopefully it won't take too long!,,Lol Regards, Marty.
Boards are now in production a should be with me in a couple of weeks
Thanks for the gerber files. When I get time, i will have a look and do a comparison. Good luck with the manual
@Martin, Thanks. The Gerbers I posted were the one's obtained a couple of years ago when I was a member of the Mirage and Crossbow forum (Area51). The Crossbow and the Mirage Projects were the first detectors that attracted me to joining Geotech in 2016. My first build was the Surf longboard because I wasn't experienced enough back then to build the Crossbow. Keep us posted on your build. Regards, Marty.
Originally posted by 6666 View PostTowySalmon would you mind measuring the outside dimension of one of the coils ellipses please
as per attachment you will see the arrows point to the measurement I'm asking about thanks.
[ATTACH]41132[/ATTACH]
