Battery Pack for Metal Detectors
  • Battery Pack for Metal Detectors
    Hello, does anybody know where i can get such a battery pack.
    http://www.detektorforum.de/smf/eige...-t66670.0.html
    I mean the one at the picture with the squirrel.
    Look around in BangGood. They have everything you would need to Make one. This has possibilities ! https://www.banggood.com/12V-Portabl...r_warehouse=CN
      Thank you for the link. I found something and i think he used this for his battery pack.
      https://www.ebay.de/itm/Alu-Gehause-...IiYajnrwP3evfA
      in size: schwarz 75x70x24mm
      His Enclosure and battery pack looks the same. Powerbanks are useful but i think i cannot drill through them.
      I only need batteries and a usb connector to charge them. Or a normal connector. I think 3x 18650 lithium batteries will fit inside.
        Be sure to use some type of Charger Protection. https://www.banggood.com/Seiko-Prote...r_warehouse=CN
          Thank you. Maybe i can use this like it is. https://www.aliexpress.com/item/Univ...785557541.html
          Do you think i can get 12v out of it when i connect the cells directly?
            If you have access to a 3dprinter or know someone that has one, you can make one with 18650's I plan to make something like it for the TGSL. if your in Canada or USA perhaps I could make you one and all you have to do is pay for the material and shipping cost.
              I have a cheap one (Anet), but i dont like 3D printed parts because they are very fragile and they dont look as good as Aluminium enclosures . And no im from Germany. I think the powerbanks are fragile too and i will use the china aluminium enclosure and buy the cells+charger from banggood.com
                I have one like that from BangGood. The cells need to be in Parallel for the charging / converter circuit . You would need to gut it and rewire cells in series . Then the charging circuit would be no good to you. If you just want the case it's nice, eeaa? Add the 12v 3 cell protection and charge with 12v ? https://www.banggood.com/3S-12V-10A-...r_warehouse=CN
                https://www.banggood.com/DIY-418650-...r_warehouse=CN
                  I already thought so. I think i will buy 3 good cells and this charging circuit and put it inside the cheap enclosure from ebay. 12V charging is ok but usb would be better, i think this is also possible.
                  Or i will put the 3 cells +charging unit in the main enclosure from my baracuda. I need to wait for my small boards from pcbway.
                  They are 58mm wide, this means i will have enough place for the batteries.
                  But i also need one for my TGSL which has a big board.
                    Or just build your Battery Pack and charge the 18650's like normal. That way you can have spare's .
