Does Ic bandwidth matter for our detectors? I was about to order spare/replacement IC and notice there is a wide range of bandwidth for the same IC is higher better, Like the LM358 you can get it in 700khz or 1Mhz, also with the 393....... same question about MA (milamp, are we better getting the highest or does it not matter?
IC bandwidth
It matters, that's why so many different opamps are made. Generally, the RX preamp needs a high gain-bandwidth (GBW) product. Others might or might not.
"mA" can mean the current consumption of the opamp, or the max output current rating.
Originally posted by Carl-NC View PostIt matters, that's why so many different opamps are made. Generally, the RX preamp needs a high gain-bandwidth (GBW) product. Others might or might not.
Originally posted by homefire View PostLower Band Width OP may work fine in the Audio Realm but NO SO in the Digital . Wider BW is required to keep square waves square. LOL Infinite number of Harmonics stuff.
Originally posted by Carl-NC View PostMy reply was "in general." If you are replacing an opamp and you don't know anything about opamps, replace it with the same part number. If the part number has different grades, get the best grade.
LOL yep, it can happen that way but in the same sense a Poor performing Op Amp may not produce unwanted side bands that the "" Better Option "" would be able to. That's why they don't just make the Best. Best at What ? Best for What ? Best / Better is a Relative thing. Price has little to do with this one.
Originally posted by homefire View PostLOL yep, it can happen that way but in the same sense a Poor performing Op Amp may not produce unwanted side bands that the "" Better Option "" would be able to. That's why they don't just make the Best. Best at What ? Best for What ? Best / Better is a Relative thing. Price has little to do with this one.
Originally posted by Tibuck19 View PostWould you happen to know what the last two or 3 letters mean on the ic's like N, CP, AB .......... they must mean something to describe a important or a bit of info?
The suffix meaning can vary among makers. So best to consult the data sheet from the maker. This will be in the data sheet under ordering info.
'N' is typically a plastic DIP.
Originally posted by waltr View PostThese letters typically indicate the IC package and temperature range.
Before I asked about bandwidth, was in part after noticing the SMD chip had a fast bandwidth availability then its throw hole counter part! while digging throw the old post I had came across this one, I was wondering if it worth the trouble just to get the 1 MHz faster.
http://www.geotech1.com/forums/showt...like-this-idea
Originally posted by Tibuck19 View PostBefore I asked about bandwidth, was in part after noticing the SMD chip had a fast bandwidth availability then its throw hole counter part! while digging throw the old post I had came across this one, I was wondering if it worth the trouble just to get the 1 MHz faster.
Sometimes a faster op-amp will just cause a headache when it oscillates.
Other times it may do good things.
