I am designing a alarm system that is similar to a personal or rape alarm as they call it where you pull a pin on a lanyard that activates a switch to set the alarm off. The pin and switch is quite a simple design. the pin made of plastic keeps apart two spring leaf contacts that close upon removal of the pin. I thought this would be an easy component to find and could not find it anywhere. What would this type switch be called and where would i find them.
Pull pin switch
Here is one example, download the data sheet you can see the contact configurations.
https://www.mouser.com/ProductDetail...xoC__4QAvD_BwE
ebay
https://www.ebay.com/itm/20Pcs-3-5mm...4AAOSwZtlZ-ywQ
