I see almost all detector schematic using dual supply. What if I use single battery say a single 18V battery just to meet opamp needed voltage and the supply rail, which supplied by charge pump can replaced by using 18V battery mentioned. Or is it related to signal phase? AC signal is there, but is it there is no other way to make fully single supply? So then it must only works by use dual supply? If using the 18V and put simple voltage divider by 2 resistor, is that option will do?? replacing charge pump for negative rail.
Hope my english understood, I still lack electronic understanding. Thanks anyone for enlightenment.
