Does anybody know whether a picaxe running at 16Mhz will provide accurate 50us timing pulses. The pauseus command is supposed to allow microsecond use but the instruction rate can be as long as 100 - 200us per command?
The Arduino nano detector (thanks George) certainly copes well with these pulse widths but maybe the nano is much more efficient or the programming real clever?
Perhaps I should try a picaxe loop program of typical pulses and check the results on an Oscope but I thought someone may have tried in the past.
