http://www.sskteracon.com
A controller intended to turn PC into a process control / data collection system. With the appropriate sensors the controller can monitor physical variables such as pressure, temperature, light intensity, weight, movement etc, process the information and then use the result to control up to three physical devices such as motors, heaters, sirens, lights or other appliances around the home, office, laboratory or factory . You can program your appliances to operate automatically in conjunction with your weekly and daily schedule, manualy turn them on/off from your PC or use the controller as a process ON/OFF controller to regulate some kind of physical variable ( PV ) to the desired value ( SP ).
