Does anyone know who makes a Vernier dial with a coarse adjustment also?
Simply attach a set screw collar to the the part of the Vernier dial which goes on the shaft. If you cannot find a wide enough collar, you can remove the collar from a set screw knob, and put a long screw in it (you might want to cover the exposed threads).
You're welcome.
I just realized that if you cannot find a wide enough collar, you can just put a long set screw in the part of the Vernier dial which goes on the shaft...
