Kung Fu Flash
  • Kung Fu Flash
ID:	414607Click image for larger version
    Retro mania!
    I just finished 5 of this cartridge, I use the rare moments of peace in the room while my stepdaughters sleep!
    The PCBs were made in JLPcb, they also did a partial assembly, all that was left for me was to solder the micro SD holders and micro USB connectors as well as write the firmware into the processors.
    And it worked!
    It works as it should!
    Yeee!
    Only 2 of 6 images can be seen. First 4 are blank.
      Can you see these?
        Ok, I get it now!
        Bklein has the same problem on this thread: https://www.geotech1.com/forums/foru...eld#post414622
        And I even made a joke at his expense!
        This is a job for Carl. The forum engine has gone crazy and something strange is happening, I didn't realize it until now, until you alerted me.
        The crazy thing is that I can still see those 4 pictures perfectly normal!???
        I completely deleted "History" from my browser, tried again; alas, I still see all 6 images correctly.
        When I hover my mouse over the last 2 pictures (which you also see); the zoom pointer appears normally.
        But when I hover over the first 4 images; no pointer??
        And that is an indication to me that they "do not exist" on the server???
        The situation is identical with the picture that Bklein posted on another topic, he still sees it and Carl and I don't???
          Up to this moment I never used Brave browser, so it is "clean" from any cache on my computer.
          So I checked with it and I still can see all 6 photos I posted???
          So it is not local problem at me.
          This is problem at server. I can see my photos while others can't.
          Also Bklein can see his posted picture and the rest of us can't.
          WTF???
          What kind of problem is that?
            WTF???
            Is this because you have the photos on your computer, and that's where it finds them.
            Try renaming one of the photos on your local disk drive, and see if it disappears when you view your forum post.
            By the way, I cannot see Bklein's photo either.
              Can you see these?
              Yes.
                Ivconic - If you try quoting your post with the missing photos and look at the code you will see there is no attachment number assigned to the first few images. Did you attach all images using the same method?
                  Most of the time i "Copy" the pic or photo and directly "Paste" into post area. So far I haven't similar problems.
                  Rarely I do upload from disk folder "temp", on C: It is "transitory" folder and files are not staying there for long time (habits from the DOS times).
                  I don't think the problem is in what and how I do it. Plus, the same manifests itself with the bklein image.
                  Some minor problem at forum scripts I guess.
                    Guess what? Now I don't see first 4 photos either, only last 2 I can see (in my first post here).
                    Something changed? You did something? Carl?
                    I see only placeholders like this:
                    Click image for larger version  Name:	image.png Views:	0 Size:	11.9 KB ID:	414655
ID:	414658Click image for larger version
ID:	414659Click image for larger version
                          I haven't done anything, no idea what's going on.
                            I found a thread about this on the vBulletin forum but it was not resolved. Most likely there was a glitch during the upload of images to the server and they did not get saved. Ivica can still see the images because they were cached on his PC for a while, and then the cache cleared and they disappeared for him as well. I think there is nothing I can do on the forum side.
                              But I already explained that I cleared both history and cache.
                              And just in case, I opened the page in the Brave browser, which I had never used until that moment (Win10 has it, but I didn't use it).
                              Apart from those methods, I have another one, I use Total Commander to manipulate files and media and it has the option
                              Configuration-Option-Display-Show hidden files.
                              With that option active I can see all files in ...Users\WhateverUser\AppData\Local, Local Low and Roaming hidden folders.
                              Those 3 folders are the place where all programs have some settings and cache.
                              There is a subfolder "Temp" which contains the current cache and other "junk".
                              Deleting everything from that folder literally physically deletes the cache and all temporary files and folders.
                              And finally, above all; I activate Ccleaner and clean everything with it.
                              After those actions, if the system is restarted again; works much faster and relieved.
                              These are some of my habits from the DOS era, of course then I used some other software similar to Total Commander, Norton Commander, Volkov Commander and similar.
                              I mean; whenever something suspicious appears in the behavior on the system or when interacting with the Internet; I do all these actions, it's almost a routine for me.
                              And despite all that; I still saw my pictures in the post until some time today.
                              And then a moment later the first 4 are gone as George immediately warned.
                              It would be good if bklein now says if he still sees his picture on another topic. You may be right Carl, but then does that mean there is some place else on the system where Win10 is duplicating the cache??
                              I've used Win7 for years and know it well.
                              But I've been using Win10 for a few months and more (forced due MS fooling around) and I can't say I know it very well.
                              Is it possible that Win10 has some "secret" place where it leaves an extra copy of the cache? I doubt! I do not believe.
                              For the above reasons I don't think it is a problem on my system.
                              I'm more inclined to believe that the forum engine "hiccuped" for a moment, or some script, some setting...
