ADC resolution increase, I bet few knew about these two facts.
  • ADC resolution increase, I bet few knew about these two facts.
    It is generally known that adding white noise signal gives 1/2 bit resolution each time you double the number of samples.
    Another way to state this is that n samples reduce the noise N by the square root of the number of samples
    But who knew that a simple low-pass IIR filter y_t = (n - 1) y_{t-1} + x_t improves that by a factor ?
    \frac{N}{\sqrt{2n-1}}
    From this article: https://www.electronicdesign.com/tec...duce-adc-noise
    But it can get even better, who knew that adding triangle noise gives you +1 bit improvement each time you double the number of samples?
    From this application note by ST https://www.st.com/resource/en/appli...lectronics.pdf
    Click image for larger version  Name:	Schermopname (340).png Views:	0 Size:	175.8 KB ID:	418757
    Yep, adding dither is pretty standard in audio engineering.
      Most of us know about the white noise dither, so this post is about better options that are less known.
