Hex Schmitt Trigger
  • Hex Schmitt Trigger
    "...MC14584B Hex Schmitt Trigger is constructed with MOS P–channel and N–channel enhancement mode devices in a single monolithic structure.​.."
    I am considering White's TM-808 and some modifications. I'm curious what other, easier to get, maybe more "modern" circuit could adequately replace this?
    Any other hex Schmitt inverter? There are several in the 4000 and 7400 series.
      Not familiar with the TM808 circuit, The MC14584 can be replaced using a CD40106. Same pin out
          Just finished a tedious service of one TM-808, came in hard condition, previous "meister" busted it totally up!
          Not only that: he dismantled the TX&RX setup and simply pushed those small pcbs in a tubes without providing that antenna goes through the toroidal coil !???
          Simply just "hided" them deep in a stem tubes!
          Expecting to work like that... a magic!
          Long story short; I fixed it and it is working quite alright. No problems at all.
          Compared it with my previously made TF900 and can't notice significant differences in performances.
          Yet... I am the man of many "complications"; I like to make my life complicated!
          So I have a desire to make a copy of this one too.
          4 things I will like to change here:
          1) 78S40 although it still can be obtained in local stores; I would like to replace that part. It is adjusted to provide 15V single supply, later divided by half with "virtual ground" trick... as on many White's.
          I would use LiPo 3.7-4.2 high capacity battery and dc/dc stepup from one of those modern ones.
          2) Famous White's multi-switch, can not be obtained, so I will use rotary 4x3 switch instead.
          3) Audio is boring, carrying so few information.
          VCO, variable pitch and volume related to strength of a signal/detection.
          4) Replace 4024 with 4040 and use available crystal.
          Probably draw more compact pcb, omit few redundant components etc.
          Interesting. I will put it on my "todo list" for the near future.
          Not 100% sure that I will do it, yet... it will wait on the list.
