test equipment grounding confusion
  • test equipment grounding confusion
    My brain is getting whacked by test equipment grounding issues.
    Turns out my signal generator output has one lead grounded. My oscilloscope has a ground. Both grounds are connected through the three-prong power plug.
    If I want to inject a signal somewhere in my circuit, I have to think carefully. One lead of the signal, being ground, will automatically make a short circuit to wherever the oscilloscope ground is.
    I can use an isolation capacitor, but then I still have an "AC" short between those two points.
    I can use two oscilloscope probes in "differential" mode to try to avoid attaching the oscilloscope ground, but sometimes you get a poor waveform without having a ground reference somewhere in the circuit -- I think. And then each probe will still measure zero AC volts relative to the grounded signal lead -- not necessarily bad, but can be confusing, especially when you leave differential mode and expect floating probe signals but get distinct measurements relative to ground.
    I could also use an "isolation" audio transformer to isolate my injected signal from the signal generator. Is this worth it? What does it mean to apply such a floating signal across a differential amplifier for example? Do you need a "ground path" somewhere anyway.
    I don't have power isolation transformers, but if I did, would I want to use one on my oscilloscope and one on my signal generator, so each is floating?
    I would be interested in a thorough discussion of such grounding issues.
    Power isolation transformers can be very good decision to prevent to destroy your (probably not cheap) test equipment and to solve such problems in future. But there are still power grounding line which have to be the same for all equipment (not derived from 0 power line from diferent phase line outlet, but real grounding line) or not grounding by TR split equipment at all.
