Schematic HH performer 150W
  • Schematic HH performer 150W
    Hello,
    I have the amp HH performer 150W
    and I search the schematic.
    Is some one can help me ?
    Thank you
    Originally posted by pio View Post
    Hello,
    Thank you
    Pio, is this your machine?
    Professional Guitar Combo Amp
    Total Weight: 39kg!
      yes it's this one
        Pio, you are in metal detecting forum. Search this link:
        http://www.soundservicesni.co.uk/dow...schematics.htm
          thanks
          I found this link but in this liste, I don't find the HH performer diagramm
            thanks
            Pio, I think circuit VX150 is fundament of your machine.
              I don't know if I understand (i'm french).
              You say that the HH performer is based on the diagramm of VX150
              But the VX150 is an audio amp
              see http://www.tv-bay.com/FORSALE/Audio/...er/112288.html
              Do you know the performer amp ?
              My problem is the channel 1 doesn't work and the sound is very bad
              I don't know if someone else, before me, modified the wiring inside the amp, or if the problem is electronic.
              That's why I search the schematics.
              also the LED of channel 1 and 2 are switch on at the same time.I don't know if it's normal
                Pio, if the other channel works fine, you can compare both without using circuit diagram. As a first step, you should measure operating points - DC voltages of transistors and electrolytic capacitors.
                You can ask also a French forum:
                http://fr.dir.groups.yahoo.com/group...2227?o=1&var=1
                  thank you
                  I will try to analyse with your method.
                  Now, I will search in this french forum. Perhaps I will found it.
                  Bye
