i have a 709 0pamp 14 pin can i cut it ?
  • i have a 709 0pamp 14 pin can i cut it ?
    i have just one 709 0pamp 14 pin left.could i cut the nc's pins off with out damaging it? i 'm gonna try it on a surfmaster board.
    Should work fine.
      thanks. i'll get my jewellers saw out
        I've seen it done and it worked Just Fine!
          I have a bag of the orginal LM709s in 8 pin can configuration. If you need a few, send me a pm with your mail.
          Mark
            thanks for offer Mark but everything worked out ok.6 blades later .i dont' know what they put in that plastic .it's a big improvement on the 741 i had in there.thanks people
              or you could just bend off the un-used legs , place in socket over hanging each side if you have the physical room for it , only an idea , saves the risk of cutting.
                thanks dooley
                i've already cut it .it worked ok.no problems
                  Taliesin, as all other producers of ICs, Taliesin Unlimited should mark the pin #1. Drill a shallow hole in place shown below and fill it with nail polish.
