My new scope came in today,I was setting it up and the procedure was to set the controls to certain positions then hook the probe to the test terminal and adjust the pot inside the probe until the square wave was not distorted.The probes are poor quality in my opinion,they have a slider switch for x1-ref-x10 so I adjusted them,but I am not confident they will stay that way.You get a slightly different wave shape when you use the clip on accessory also.If you bump the switch with your finger you can see it in the trace,just doesnt inspire confidence.Would a non switchable 10x quality probe be a smart investment? Or should I buy a quality switchable x1-x10 probe? And the other question is my scope is a 20mhz so do I have to buy 20mhz probes? Or is that just the minimum and say a 60mhz probe will work fine? I dont quite understand the bandwidth spec yet.Thanks
Need some Scope probe advise.
I just picked up my first scope, 40mhz, without probes and made a posting on the TEK yahoo group site about probes. For our low mhz units we don't need fancy expensive probes.
They all recommended these probes which they had good luck with:
Look at #'s 8-9-10
http://s.dealextreme.com/search/probe
Here's some good tutorials:
http://www.youtube.com/watch?v=qIfo_-d82Co
http://www.doctronics.co.uk/scope.htm
Hope this is of some help to you
Probes
I bought a Tek probe on ebay yesterday I think I will like it better.Thanks for the tutorials that was very helpful,answered a couple questions I had.I do have another question.When I look at the square wave on the scope the vertical elements of the square wave are very thin,so thin you really cant see them.I have seen scope pics(on this forum I think) that look the same,so it is probably normal but I was curious.I have also seen scope pics where the vertical lines looked just like the horizontal ones.
On a CRT scope the vertical lines on a fast edge will be thin, that's normal. On an LCD scope they will be the same as a horizontal line.
I wouldn't trust cheap Chinese probes for 100MHz work, but for metal detectors they're fine.
Thanks Carl
Originally posted by Carl-NC View PostOn a CRT scope the vertical lines on a fast edge will be thin, that's normal. On an LCD scope they will be the same as a horizontal line.
