Can someone tell me what the purpose of the circled RC network is? I'm guessing it would slow the feedback response.
Op-amp circuit question.
This is the post-demod filter, where the signal "frequency" is due to the sweep of the coil, which is relatively slow. 7Hz is a pretty decent setting for an average swing rate. You could eliminate the high-pass portion (C10) if you wanted zero-motion response, at the expense of greater noise.
