Geophone Array
  • Geophone Array
    Greetings fellow treasure seekers,
    I am a novice hunter looking for a non metalic object burried 1m underground.
    In my research for an alternative to GPR I found this article:
    http://www.array-ka.com/geophone.html
    The author describes using an array of geophones to get subsurface imaging at shallow depths.
    This method sounds very appealing to me as it is low cost and perfect for my shallow depth hunt.
    Does anyone in this forum have any idea what kind of software this would use?
    Also the type of geophone would also be important in this method but I am new to geophysics and would be open to recommendations.
    thank you in advance
    The document is no more available at Lantronix site.
    Is it like patent 'Seismic acquisition system using wireless telemetry' US 6219620 B1 or WO 1998018022 A1 http://www.google.com/patents/WO1998018022A1?cl=en
      I am not sure that seismics will be good alternative to radar for small buried objects.
      I guess for small depths and for surface survey You can use just refraction method.
      It hasn't enough resolution for You task.
