Snuffler test data file interpreted by the MagPick, Snuffler, Terra Surveyor, and Wumap software.
Snuffler test data file interpretation.
I found some tutorials, but they are dated from 2004 and 2010. Maybe someone has a more up-to-date one reflecting possible changes in the MagPick software.
rael, do you have a more up-to-date tutorial ?
http://epsc.wustl.edu/~epsc454/software/MagPick.pdf
http://www.geometrics.com/files/magm...2010_final.pdf
Originally posted by ishtar hunter View PostHi
I built EPE 2003 john becker and set by snuffler software but my snuffler software do not give such as your scan .how you can get this image?
How to make image with Snuffler 'testdata.txt' file:
Craete 'New Project' from 'File' on task bar.
Click right mouse button on 'Geophysics Data' and select 'Create New Geophysics Data File'.
Enter Name, for example 'Test'.
Enter grid size /60, 80 metres/.
Click on 'Test' label.
Select File menu, 'Import Data Into This File', From XYZ File.
Open 'testdata.txt' file from Snuffler directory.
Click again on 'Test' label and select 'Preview Window' and 'Spawn Main View'.
In 'Spawn Main View' windows you can use all functions on task bar and assemble multiple grid arrays.
From 8 years I i don't have "EPE resistity meter" and I can not help you with how to operate it.
Originally posted by greylourie View PostI found some tutorials, but they are dated from 2004 and 2010. Maybe someone has a more up-to-date one reflecting possible changes in the MagPick software.
The latest 'MagPick' manual links found here:
ftp://geom.geometrics.com/pub/mag/Manuals/MagPick.pdf
ftp://geom.geometrics.com/pub/mag/Tr...MagPick-GT.pdf
