Earth resistivity survey to find buried objects
  • Earth resistivity survey to find buried objects
    The "objects" in this case being a cache. My question,for those more familiar with ERMs, is what size does an object have to be for a resistivity meter to pick it up?
    Another question, I have read that the depth of survey is half the distance between the electrodes in the ground. Assuming this is true, and you wanted to search down to a depth of 5 feet, would the meter also pick up objects buried at 1, w
    2, 3 feet, etc? Also, what is the width of the survey per electrode station?
    ERM is not the best tool in the shed for Cache hunting. Unless the Item is quite sizable I don't think you would have a chance using one.
    Width of Detection again would depend on target size and make up.
      Thank you very much, this is exactly what I needed to know
        A decent PI machine would be my weapon of choice.
          Absolutely, thats why I'm here just took a Whites TM 800 up,but wasn't getting anywhere near the depth it says on test target,deep seeking PI it is
            this cave image created with OhmMagic
              What's the best bang for the buck PI machine these days?
                interesting thread , dear homefire , you says " ERM is not the best tool in the shed for Cache
                hunting " but we know arch?ologists use this kind of tools to discover what is down with good
                accuracy , you know i was gonna buy one so explain me what's going wrong with this tool
                knowing that in my country items are far down until ten meters , and this way i've selected few
                tools but i've no decided yet which one will be the best for me
                1 / pro accumeter series from accurate locator
                2 / quattroforce , accumaster pro digital and pro accumaster VII from GDI
                so i want you to give me advice if i buy or no , thank you
                  Accumeter is the best..tested here in the philippines
                    hello ! wich brand is tested in philippines ?
                      It is possible to find buried caches with an ERM. But you will need a real 4-probe ERM with mapping software, and a lot of patience. The Accumeter is a piece of garbage, it's a $25 toy pretending to be a serious instrument.
                        thanks Carl but if you think accumeter is a piece of garbage and a toy , which is a serious one to buy
                          What you want is a true 4-probe meter that can do Wenner-type measurements (or Schlumberger), has AC constant-current injection, and also has data-logging and mapping software. I don't have direct experience with any particular devices but I do own an Accumeter and it is a useless toy (same for Kellyco's GPL units).
                          Here are a few links if you want to see what a real ERM device looks like:
                          https://www.agiusa.com/supersting-wifi
                          https://www.aemc.com/products/ground-testers
                          http://www.geonics.com/html/conductivitymeters.html <--induction-based ERM
                          https://www.globalgilson.com/soil-resistance-meters
