Ivconic Magnetometer/Gradiometer
  • Funny, today I've checked the term 2.5D because of videogame-graphics:
    https://en.wikipedia.org/wiki/2.5D
    The "Superdetector" works not directly on Gold but on its radioactive features -
    if these treasure-hunting book claims and my scientific assumptions are correct.
    Here you can find MD-GPR combi detector for military demining:
    http://geotechru.com/
    It shows the Plastic-mines on the screen if they contain minimal metal
    and if they are buried rather shallow but overall its not mega deep so far.
    The American version is called Mineshark but the website of it was or still is down.
    GPR is no solution for 5 meters and more directional treasure-hunting !!!
    It might penetrates 5m deep but the results from there are indecypherable. *laugh*
    > In your areas probably rarely hidden the gold in iron crates
    The Nazi-Gold was even in pure wooden chests with some rusty nails. *laugh*
    But most of it has been "robbed" by the American forces already in June 1945.
    • I use to remember the results of the mag in the mikroSD, then I put it on the computer and to the 'Vumate ' (2,5D, small, free, invented on Win95).
      The effect of the image that is similar to the Ivconic. Ivconic, however, is a better programmer and has more fancy.
      I prefer constructs from A to Z, than search. Always check the efficiency.
      The older I get, the less I have free time.
      • Yes, we inventors each have different approaches. *laugh*
        Nokta Invenio measures directly the coil-movement-distances to render the find- / signal-images.
        Directional handheld magnetometer-pictures on the screen etc. could be possible
        but someone must make 360 turns every 5 or 10m.
        This way the chip should be able to compare the actual values with the recorded
        ones and finds out into which direction the EM-field becomes stronger or weaker.
        Same as an infrared-steered-missile then is possible to draw some directional
        arrow on the screen which leads to the heat-source.
        The "rosette seeker" (infrared homing) creates a 2D image from a 1D source.
        • My mag gives a beep after each measurement (measurement time is to choose, associated with tenderness), to move to the next node of the grid.
          Of course, there is also a version of the continuous measurement of the histogram.
          • The measurement nodes would have to be aligned to the 360 degree
            turns by gps so the directional distance orientation is perfectly clear.
            For this not even a gradiometer would be needed but the crappy
            earth field incl. self caused disturbances might destroy all effort. *laugh*
            • Tiny Chinese legs are shaking&trembling now; because I AM COMING!
                • Comment
                  • Comment
                      [ATTACH]46300[/ATTACH]
                      [ATTACH]46301[/ATTACH]
                      [ATTACH]46302[/ATTACH]
                      Any schematics?
                      • Originally posted by Bhathu saaii View Post
                        Any schematics?
                        • Ivconic,
                          Do you have the device for sale as well?
                          • Originally posted by stefan-s View Post
                            Ivconic,
                            Out of Serbia; no.
                            Sorry.
                            • Ok no problem, would you ever change you mind let me know.
                                No other reason from what i mentioned several times here and there on forum.
                                It's the problem to send packages abroad, from here.
                                High taxes, contradict custom regulations, complications like that, possible delays in shipment etc.
                                This is embarrassing situation for me.
                                Until i figure out some regular and 100% sure method to normally send packets to people abroad.
