Does any one know the technology of Ionic/Electrostatic Field for searching for metal or gold. How well does that work?
This topic is closed.
Originally posted by Unregistered View PostDoes any one know the technology of Ionic/Electrostatic Field for searching for metal or gold. How well does that work?
This is bogus science. Gold does not create ions.
Please read the Remote Sensing threads and look at the LRL section on this website.
Qiaozhi may be right, we've been discussing this in the Remote Sensing section. So far...- There is zero evidence that gold produces ions.
- Some homebrew ion-detection devices have been built but have not proven useful in treasure hunting.
- Ion detection, if feasible, could not possibly provide directional information.
- One company that makes so-called ion detectors, OKM, has a poor track record with their other equipment. And there has been zero user feedback on their ion device.
- Another company, Mineoro, has posted a number of user recoveries that have, so far, completely defied independent verification.
- I, and another forum denizen, have independently dissected Mineoros, and determined that they contain no method of ion detection.
- I personally own a Mineoro FG80, and I have yet to see it detect gold at all.
Originally posted by Carl-NC View PostQiaozhi may be right, we've been discussing this in the Remote Sensing section. So far...- There is zero evidence that gold produces ions.
Cause they claim that in order to produce ions, the gold has to be buried more than 10 years.
I guess this part is very diffcult to prove, but if it works that will great.
Originally posted by Unregistered View PostWould that be the same for old buried gold more than 90 years old.
- Carl
[QUOTE=Carl-NC;47817]This has become a common alibi of LRL manufacturers, to avoid the simple randomized blind tests that prove their devices don't work.
well if that is true for LRL manufacturers, are there other devices, not necessarily long range, that can positively detect 90 year old gold in an area not more than 1000 square foot?
No mention of gold... I'm trying to get more info.
- Carl
If is impossible for gold, is impossible for all metals...
If can migrates from depths to the surface, why the air will be an obstacle?
Why can't migrates gold ions?
http://www.innovation.wa.gov.au/Inno...bile_metal_ion
http://www.mmigeochem.com/Wildcat310706.pdf
Ionic exchange : Ground to cloud
First, Thank you Carl for this forum.
My own position on LRL's is poor but I accept Carl's evaluation as sound and as strong as oak.
On the thread of ionic emmision of metals, I do think that they can both souce and sink electrons. Not of themselves but from the environment. Hence we have Mr. Ben Franklins Lightning arrestor and much to do to protect people and property from the damage of lightning. At any one time there is a global exchange of energy in the form of lightning, and we know the effects of solar radiation in the form of flares that produce excellent displays of light in the northern skies. So, my question is,... can a mineral reef exhibit a greater path for these charges to equalize? I have seen sticatto lightning in mineralized areas and it appears that lightning will strike in frequency, in some areas (a NASA study, FL.) . There may be underground mineral conduits as there are man made that facilitate the winning path to/from earth ground. Can equipment survey these areas? What would we be looking for? Positive, negative or either?
Can the ground be surveyed for electrostatic charges? Would this be of benefit in areas of known mineralization? LRL's do not work, and lightning does strike twice.
Thank you,
A.S.
Got some answers
Found some interesting sites on ions and electrostatics:
Air ion counter instructions http://www.trifield.com/ion_counter.htm
Counting atmospheric ions: *homebrew* http://www.sciam.com/print_version.c...81809EC588EF21
electrostatic Voltmeter http://www.trifield.com/SurfaceDCVoltmeter.htm
Pigs in space: BBQ Treck http://www.belmont.k12.ca.us/ralston...apter%20VI.htm
The last one is as good of proof that LRL's work as it is proof we walked on the Moon! And to think a 12th grader wrote this!
Not looking for a debate, just asking questions in light of geotechnology.
thanks much,
A.S.
Mistake
"The signal current will be fantastically small--the ions in the air inside your home might generate only 10-15 amps. (Outside sources should produce a somewhat larger current.) To become a detectable signal, such a tiny current must pass through a huge resistance--in our case, about 10 gigaohms."
"When forced through such a large resistance, the tiny signal will generate about 10 microvolts, which a high-impedance operational amplifier,"
The sci american article has a mistake, the 10-15 amps
should be "10-15 Femto amps" {10x10^-15}
Building an electrometer.
And NO, electrostatics at this level WILLNOT move rods.
Sorry
Originally posted by JAFAL View PostHi sir
I do like to talk to you if you pleas
