LOCATING BURIED TREASURES....part 2.
  • LOCATING BURIED TREASURES....part 2.
    Hi folks,
    What a morning! Put the nets out last night and
    caught about 3 and a half kilos of Yabbies and
    three beautiful little Rainbow trout on a jig with
    a Rod. Exciting stuff!
    Continuing on in the "Geochemical" instruction
    book. Page 24.
    STEP#3: Put 20 grams of 80 mesh screened sample
    into a clean jar[it must be rinsed with distilled water].
    Add 40 ML of distilled water to this sample and stir
    very thoroughly for several minutes.
    If you have more than one sample use the low cost plastic foam cups bought from any grocery store. Pour 40 ML of distilled water into each cup
    and add 20 gram of sample to each cup. It is possible to use only 10 Grams of sample and 20 ML
    of water.That is always twice as much water as
    sample by weight. If you have no ML measuring cup
    merely use grams of water. That is,if you have 20
    grams of sample, weigh out 40 grams of water,or if
    10 grams of sample use 20 grams of distilled water.
    STEP #4: PUT THE SAMPLE LIQUID INTO THE
    GEOCHEMICAL METER CUP.
    Now pour the liquid from each sample into the cup
    on top of the Geochemical Meter. The liquid must
    completely cover the little stainless steel button on
    the top of the meter cup. Wash out the Geochemical
    Meter cup after each sample is read. To do this,
    hold the Geochemical upside down and use a good stream of distilled water from a plastic squeeze bottle.
    STEP 5#: ADJUST THE METER.
    If you don't have a pretty good idea what the reading will be[which is most of the time] put the
    meter switch on the highest number[1000] before
    you push the button. Continuously pegging the
    meter can eventually damage it.Always make the reading on the most sensitive scale[lowest] scale.
    Any time the needle reads less than one on the meter face, turn the switch to the next lower reading.
    STEP 6#: DETERMINE THE PROPER READING.
    The meter reading is determined by both the switch
    setting and the needle reading. Multiply the reading
    on the needle by the switch setting for the reading.
    The reading is in microhomos which is a unit of
    conductance,but this is not important. Simply use
    your reading as given by the meter and switch
    setting.
    STEP 7#: RECORD THE READINGS.
    Keep a sheet of readings. Be sure to number each
    sample reading on the sheet. This will be later transfered to your map grid.
    STEP 8#: IMMEDIATELY CLEAN OUT THE CUP
    ON THE GEOCHEMICAL METER.
    It is extremely important to wash out the cup within
    a minute after reading the last sample. The chemicals in the ore can damage the tiny wire in the cup.Always wash out with distilled water.
    Be sure to wash the meter clean and your sample cup clean with distilled water before and after each test. Use a squeeze bottle . That conserves distilled
    water.
    STEP9#: TRANSFER THE READINGS TO THE GRID ON THE MAP.
    Draw a line around the areas that read the highest.
    STEP10#: FURTHER SAMPLING.
    Go to the areas that read the highest and do more sampling on a 25 foot grid or even a 10 foot grid.
    Transfer those readings to the map.
    Once step 10 is completed you should be ready to start digging. Do sampling in the hole as you go down. If you have a drill it would be best to drill a
    number of test holes and run a geochemical every
    5 feet as you go down. After you have several holes
    drilled and tested you will have a much better idea
    of where the treasure might lie. make a drawing of
    a cross section of the ground and list the meter
    readings. you will soon see a trend in one direction or the other and that will tell you where to drill the next hole.[use only dry drilling as a water drill will
    prevent the geochemical tests]
    . If you would like more
    infomation, the Geochemical Book can be bought
    for the pricely sum of about $11 US[97 price]
    from "Action Mining".....www.actionmining.com
    Just order a catalogue.
    Cheers all and have fun!
    Marsh.
    Re: LOCATING BURIED TREASURES....part 2.
    sounds like a simple conductivity meter..
    and a cheap one at that (no design to prevent
    damage to meter) with no specificity at all...
    glad me no buy this product--or the claims about..
    resistance is the reciprocal of conductance..
    r=1/s (s=conductance in siemens r=resistance in ohms)
    the terms "siemen(s)" and "mho(s)" are interchangeable
    reg-rick
    >Hi folks,
    >book. Page 24.
    >setting.
    >water.
    >Marsh.
      Rick : How about a Fluke 8020A DVM, and use 91% Alcohol to clean the probes with, no film, quick drying. The Fluke has Ns selection(nanosiemens) and range scales. I might give it a try this winter. Regards Marc
      >reg-rick
        Hello Rick,
        Thanks for your comments!
        The meter spoken of in the "Geochemical"
        Manual is a Myron EP 10.
        The small meter is a "Corning" CD 55.
        Are these cheap Meters and if not can you tell me
        where on the Internet someone could buy
        the same one,s for less .
        Are you saying that the Information in the "Geochemical" manual is dishonest and misleading?
        Thank you,
        Marsh.
        PS. Anyone else familar with these meters?
          my "position" is that if it was my product-in the
          interest of correctness at a minimum...to have a
          design that "pegging" the meter can cause damage-
          and to resolve this potential problem by having
          the customer do that to compensate---is totally
          unacceptable..the document presented is its own
          enemy/allie----stainless steel electrodes???
          there are many a type stainless steel-304,306,310...
          all of which are unacceptable---a typical "conductivity cell" uses platinum electrodes
          as material of choice..there is many more points
          also---and this document to the technically minded
          places things in the proper perspective..what if
          the field you are testing was a time ago for
          say moo moo cows........well they put out salt
          (nacl)blocks for them to lap on....the rain/salt
          urine/etc.....the spot you decide to dig might
          be just where the block sat the longest.....without
          any differentiation in that specific ions that cause
          the indication of conductivity ??????distilled water??
          even tripple distilled water----reverse osmosis---
          and so forth---ion exchange resins---zeolite.
          where for you to buy ???????me no say me know me
          no buy-----because of their document----and the
          viability of the techniqe----you decide...
          >Hello Rick,
          >Thank you,
          >Marsh.
            Rick: Thank you. I missed the Stainless Steel part. Stainless steel is a horrible conductor. The crystaline structure is highly resisent to DC voltages. One of the more common mistakes new engineers make is to just stainless steel as a conductive amterial. Its' claim to fame is it's lack of surface deteriation compared to steel or copper. Not its' electricial value. Regards Marc P.S. I could tell you stories about friends that wired boats for the Gulf with stainless and wondered why the lights didn't work. They replaced the conections with copper and it works. LOL Marc
            >>Hello Rick,
            >>Thank you,
            >>Marsh.
              you certainly could try this first---assumeadly you
              have meter---be aware of the instumentation limits
              you have---so as your mind to (hopefully)compensate-
              if you see cow dungs.......it would not cost any
              (9v) but still----frozen ground----me no never
              investigate conductivity hoh solid phase.....
              a little more to illistrate on document....a time
              ago was interested to purchase a small screen
              portable color tv....for tv as well as a color
              monitor for homemade computer..(even before trs80)
              well to shorten story some---me go in store-salesman suit talk...me say show me schematic on tv....
              many tv have no schematic then some did 50/50...
              no schmatic--me no buy---yes schematic me look---
              no not that one---no not that one either---then
              finally---all right this one---design looks clean
              ok and floor model--$75 less---sale...easy modify
              for computer---tv worked for ~20 years then the
              jug gassed (picture tube went bum)....
              >>reg-rick
                not because of bad conductor (electrical and/or
                thermal) but because of the lack of innertness...
                >>>Hello Rick,
                >>>Thank you,
                >>>Marsh.
                  the resistance should matter if high current---
                  not on the current level of this type device
                  >>>Hello Rick,
                  >>>Thank you,
                  >>>Marsh.
                    oh yea --jug went bum--tv never had any problem
                    ever--in that time...0...nada....zero...
                    >>>reg-rick
