How to use ERMs for treasure hunting?
    Originally posted by 1843 View Post
    Here is the data:
    [ATTACH]3252[/ATTACH]
    Use VUMATE program to display. You will find it on Google.
    You need to add d3drm.dll for Vista.
    Rename attached file out2.txt to out2.grd
    The file was done by Surfer8 adding coordonates on your file.
    With Vumate, select File > Open Surfer Ascii grid > Out2.grd > Contour >OK>OK
    With left click turn the 3D display
      Here's some good info on ground resistivity.
      http://www.heritagegeophysics.com/images/lokenote.pdf
        Thanks Klaud and Tim for your helping!
        Best regards,
        1843
          Which one is better for treasure hunting?
          1. Twin-probe (C2 P2 remain in fixed position and C1 P1 are mobile)
          2. Pole-pole (C1 P1 remain in fixed position and C2 P2 are mobile)
          Are they the same?
          Kind regards,
          1843
            More about electrode arrays found at follow link:
            http://www.geomatrix.co.uk/Introduct...istivity_a.pdf
            http://www.geomatrix.co.uk/appnotes.htm
            Rael
              1843 yes they are the same. This method is good for seeing down about 3 feet with the probes set apart at 1 meter. If you open the probes father like 2 meters then the depth will increase.
              Tim
                Are they the same?
                Kind regards,
                1843
                NO...they are not the same.
                In the twin-probe method, the fixed probes are spaced VERY CLOSE to each other. Twin probe measures "resistance" in ohms.
                In the Pole-pole method, the fixed probes are space VERY FAR from each other (infinity). Pole-pole can measure "resistivity" in Ohm/meters.
