A small cave detector for to easy make yourself.
CAVE detector diy
Hello Epitopios , no it is not the same ,this one in the page link is a ultrasonic detector to use in air...
Hello Zenit52, yes you use a mini cassette recorder integrated amplifier to amplifies the sound of the piezo...you must fix the piezo well in the pvc tube with epoxy and place a smouth rubber(like bicycle rubber) to protect the piezo ....
The piezo must have contact with soil ...you maintain it with pvctube...
The echo came when you percut with a mass at the vertical of the hole ....
You must have a minimum volume to resonate let say 1X1X1 to resonate ...
This simple and cheap configuration work great for the price.... for discover chamber or tunnel to 2-5 meters depending of the volume of the cave and the weight of the mass....
Alexis.
Originally posted by Alexismex View PostHello Epitopios , no it is not the same ,this one in the page link is a ultrasonic detector to use in air...
Alexis.
Did you try it???
Hello Geo , yes i make it , it work but for more sensibility you must use a geophone o make it with a magnet and a coil (1000 turn minimum), also in this link you can buy it , i have buy geophone and it is the best and their are cheap because of used , also i have the amplifier
http://psn.quake.net/geophone/index.html
http://psn.quake.net/eqamp.html
the technique is simple you make a percussion with a big mass and you "listen the echo " with your geophone
Alexis
Nail gun or impact electric driver.
Did one experiment with above as wave impact generators?
Would be nail gun suitable and what distance for locate
caves or underground bankers?
Could one brief why sensor must be low frequency?
I thought that shock wave in the ground travels faster then 10Hz
so there is need for wider range of response.
Did one try to make geophones out of old large speakers?
I better ask before try.
Maybe Yukon DSAS - Directional Sound Amplification System?
http://www.sailgb.com/p/Yukon_DSAS_D...cation_System/
Better than dropping a heavy weight???
So what if I rig up some sort of nail gun to make a big thump? If the gun uses a blank .22 cartridge it can really make a large THUMP and it would be easy to use. Not certain if you can get these nail guns outside the US but I might buy one and try it.
I found a link to a test.
http://www.aeic.alaska.edu/input/west/22source/
Just an idea.
Fitz.
Is there somebody who know examples similar to http://www.aeic.alaska.edu/input/west/22source/ but that show how with seismic sistem can to detect small objects from 1m to 2m diameter in depth 2m , 3m or more in loam?
