My test by okm exp4000-visulizer3D
    Originally posted by ishtar hunter View Post
    oh oh oh oh you don't have any information about any geophysical detector and any information about exp4000 or 5000 or visulizer3D.i was sent original data of scan, if you need see real you must interpolated and add your scan point (resolution in v3D) i sent this scan to you,,, ssssseeeee // sssssseeeee and i scan by exp4000+visulizer3D if you see data is v3d but i export to jpg until you can see there and I bought my machine from people like you who can not work properly,The price is too low is commercial Trick. Because most of buyers didn’t know philosophy of circuit:::::::ohh when i don't test don't buy detector, soory
    I do not need to advertise because I'm not Seller
    in uploaded pictures as I said later, there isn’t resolution ,. Special when target is small relation to search coil .
    and about 3D picture , Z axial , produced by software!!!! . At output of 4000 detector,
    There isn’t Z axial signal. Result, image is stimulated not real !!!!!!.
    You lover OKM , there fore I don’t decide polemic with you . END .
      I do not have time for your stories
      I know, you have time only for promotion of nonsense and virtual hi-tech toy.
        You don't work by 4000 if you have information about 4000 and visulizer you don't say this .my friend i put a non ferrous metal for1yearso scan ,if you know ,,,,understand okm device can not detect new buried metal my metal isn't Ancient metal and show in scan low signal and per pulse for this scan is 25cm.and my scan size is not small of metal.
        okm detect in2meter depth and find a Boxes full of gold bullion This is why you see the signal z axial -for Analysis visulizer 3D you must Have practical experience and forget the catalog of 4000
          ishtar hunter can you show any geophysical company or institute that use your devices - OKM devices ?
            Hi
            You must ask this question from okm because i don't producer or seller this device ,i have a exp4000 and show my test by this device for all& I do not have any obligation to convince you .
            I was not happy with the device I, It sold. and i don't know how company use this device and this device not Industrial equipment until company used for example : for company use the mala GPR is very good device but okm device is magnometer
            I say again that i show hear my real test by detector and i don't need to advertise to okm.you can Believe me or not & I'm not different because I'm working myself.
            Thank's so much
              Hi
              Thank's so much
              Can you post your test in geophysics forum http://forum.detectation.com/ ?
              We will read professional comments very carefully!
                Hi
                I have a problem by a scan if you can read professional i sent this scan for you and you help me .if you can open my v3d data i sent original data to you (for open this data you need visulizer3D software ) if don't have software i sent the jpg file ?
                  Hi
                  ishtar hunter = OKM hunter , i am sure - OKMs devices are junk. If you are not from OKM, post your test in geophysics forums http://forum.detectation.com/ or http://www.geoforum.com/ and we will read professional comments very carefully!
                  OKM hunter , i am sure you will not post your test in these forums !!!
                    for you
                    ohohoh--hahaha
                    1:I am not from okm i live in azerbaijan
                    2:I say to you if you can read professional comments very carefully! i sent you my scan, i don't sent to your site you can after reading sent(put) to your site
                    3:How i sent you?data v3d? or jpg of scan?
                    4:i scan a area and so very deep dig this area i sent you so if you can read professional comments very carefully and i Confidence i sent other scan test to you ,because i dig this scan area and I know the results
                    5:If you see my scan of Grave and picture of detection you understand because i scan that area so dig and I found a grave i say i dig i dig and found a gravebut not problem you first analyses my dig scan and so i sent my test to you ..I am here
                    6:you dont red my post good :i say for okm device is not fake device but okm a device is need to set by other metal detector because for understand analyses scan you need a metal detector and okm Like other metal detector too have problem for himself
                      ohohoh--hahaha
                      What city of Azerbaijan ?
                      May be I will travel to your city !!!! …….
                        yashasin azerbaijan , yashasin turk millati.
                        which city of azerbaijan?
                        good luck
                          They say I am of okm but you know i am not from okm company .red your private message
                            Ok
                              ishtar hunter , OKM hunter , I did not write that you are from Germany! OKM is in Germany, but owners of OKM are not germans. You can find german producer of OKMs magnitometers in german treasure hunting forums !
                              OKM hunter do you wish i write from where are owners of OKM ?
                                not problem, i'm user.you can write
                                What was your read professional comments very carefully!??
                                I have a problem whit that scan you don't read professional comments very carefully?
