Diurnal and other variations
  • Diurnal and other variations
    Hi all,
    I don't have my testbooks down here with me but I'll try to
    summarize what I can remember.
    The diurnal variation in the earth's magnetic field is very
    small - typically just a few nT and, because it takes 24 hours to go
    through its cycle, it is not much of a problem anywhere - even for
    single mags. Near the magnetic equator, there is a phenomenon
    called the equatorial electrojet which occurs daily, has a magnitude
    of (I'm not sure of this number) about 50 nT or so. But, you have
    to be close to the equator to see this and it only lasts for a brief
    period - less than an hour. I'm somehwat hazy about these numbers
    because I've never been much interested in the equatorial
    electrojet..
    Globally, you can have magnetic storms - these are large scale
    things and affect the whole world at higher northern and southern
    latitudes. These occur fairly rarely - only a few times per year
    but are more frequent as the sunspot numbers get larger. We happen
    to be just entering the peak of the sunspot cycle. Magnetic storms
    have magnitudes of perhaps approx. 100 nT and last for days. That
    is, for days, the magnetic field will vary over ~100 nT range. The
    variations are typcially fairly slow, taking place over hours of
    time.
    Magnetic substorms are seen at auroral latitudes (i.e., Alaska
    and most of western Canada)and are probably the most troublesome.
    They can appear over a period of just a few minutes, have magnitudes
    of approx. 500 nT and last for up to a few hours. They also are
    more common as sunspot numbers increase. During peak sunspot years,
    they can occur very frequently. In Saskatoon, Sask., where I lived
    most of my life, we might get as many as 100 of these per year.
    They occur mostly around magnetic midnight (contrary to what Dale
    Seppa's reference says) but can be as early as 6PM or as late as
    6AM. Because the onset is so rapid, these would pose a real problem
    for users of single mags. However, they rarely occur during the day
    (instances are known).
    With a gradiometer, you are insulated from ALL of these - none
    of them have any effect whatsoever! That is the advantage of using a
    gradiometer.
    Jim
    J.A. Koehler
    3290 N. Koehler Rd.
    Florence, AZ, 85232
    Ph: (520) 868-1156
