My Magnetometer TE-MS1
  • My Magnetometer TE-MS1
    I designed a magnetometer and I am testing now. I wanted to share with you.
    http://www.teknolojiekibi.com/yeni/i...topic=4459.160
    This is final state of magnetometer project Click image for larger version
      Looks like a decent device. What is it comprised of?
        Thank you. A magnetometer sensor, a data logger and bluetooth pc cominication modul, a battery and a tablet pc. I am using my onw 3D program.
          I understand. So it is a single magnetometer sensor, and therefore it must be used in vertical position. Any chance for 2 sensors in differential configuration?
            There is one sensor. But if you want you can use two sensor. Also I have a different sensor type.
            http://www.youtube.com/watch?v=ZbrCerD-_KY
              So, do you offer it and for how much?
                http://www.teknolojiekibi.com/sales/manyetometre/
                  Thanks.
                    hello pasha
                    is it a problem for you and your friends to build an optional english site with prices in euro, gb pound or us dollar?
                    and a list with shipping prices
                    i am highly interested in two of the small sensors and a small analyzing circuit which is build next behind the sensors
                    regards and much succes
                      Hello
                      I will make some different languages as soon as possible.
                          Hey Pasha , How much price , It can detect gold as well, Cavity , Tunnel Thanks
                            You can detect cavity and tunnel and wall in the soil. You can contact with us for price.
                              tuesday this week i received my sensors EMS-100 including the diferential amplifier circuit
                              hope i can Show my build here and can get some help, but for the Price i think i would be better if you put the µController unit for led and Audio Output to the delivery, i know it is free on the teknolojiekibi Forum but most peaple will have problems to write the atmel Controller und etch additionel pcb what is needed
                              i have the cicuit for µController already, i hope i can connect all right
                              some additionel documentation would not be bad, because i have to find out how to connect right
                              the two sensors are already connected to the differential amplifier and so far i can think the will be powered by the µ Controller baord, right?
                              p.s. it was total useless to scratch the ic, i didnt want to copy this circuit for me it was for learning but Scratching the ic Labels is silly
                              whe have this seen on other Commercial Units, the only Thing you do with this Action is Frustration, i i would find some similar ic with better Parameters here in Germany i could replace the and test- but now i cant
