Re: Trucks at 10 Feet and New Mag On The Block??
  • Re: Trucks at 10 Feet and New Mag On The Block??
    There is a PI design on the market now - The VibraProbe. The selling points for it are:
    - It vibrates when near metal, which makes it good for use with headphones (for the main detector), or near surf - so that you need not strain to hear a beep.
    - It's waterproof - so again, it's good near the water.
    However, the detection range is less than 1 inch.
    I think if low cost / simplicity are needed, PI seems like overkill. A design factor I failed to mention the first time around is the need for a small coil. I picture the whole 'coil' fitting into a 1" (or so) diameter PVC pipe, with the coil at one end and the circuitry at the other end (maybe inside the pipe, maybe in a box)...
    Carl - You mentioned a VCO design - is there a reference to this type you could point me towards (no pun intended!)?
    thanks - Mark
    Re: Suggestions for a 'pinpointer' design
    thanks - Mark
      Terrence:
      I STILL thing the most affordable rapid possiblity for your search
      is a good two box detector although there is no doubt a good mag
      would be better. A lot of time I (me-moi-yo) don't get to use "the
      best" and just have to make do with what I can get. If only
      (really) ten feet I guess I would have a lot of probing in already.
      Anyway, the following, IF AS ADVERTISED would solve your problem.
      CST Corporation.
      LOCATOR FINDS FERROUS OBJECTS 15 FEET UNDER GROUND: Ideal for
      finding steel well casings, iron pipes and valves, re-bar, corner
      markers, septic tank handles and more.
      Easy way to locate small nails down to 6", large nails down to 8",
      marker stakes down to 7', cast iron pipe and manhole covers down to
      8' and large iron tanks down to 15'. LCD display has digital and
      bar graph plus audio signal. Easy grip handle. Waterproof up to
      housing. Of/On, volume and sensitivity controls. MAGNETIC TOROIDAL
      sensorS [note plural - das] and patented electronic balancing
      circuitry. Low battery voltage indiccator. Shipping weight 4
      pounds. Requires 6 AA batteries. Soft padded case. Made in USA.
      US$629.99
      Also, I note that the Fisher FX-3 is called a differential induction
      magnetometer and they CLAIM Civil War 24 pound Cannonball down to 3
      - 5 feet. You might look for a review on this unit and see if they
      say anything about big targets. (I dug up Stephen Ryland's book on
      the Fisher Gemini-3 and in there he shows the Fisher FX-3 good down
      to about 12 feet for something the size of an automobile. So MAYBE
      truck to 15 - 20 feet???
      One idea is that your local utility company may well have some of
      these pipe locator type of magnetometers. Based on the depth claim
      for the CTS unit and the Fisher unit mentioned above, they may have
      a unit which MIGHT work. Also I would think that some of the better
      tool rental places might have the CTS and/or Fisher or other makes
      for rent.
      [email protected]
      103 North Sixth Avenue
      Virginia, MN 55792 USA
