Possible coatings for Toroidal Forms and Coils????
  • Possible coatings for Toroidal Forms and Coils????
    July 19th,1999
    Rick,
    I haven't been able to find the magazine that had the ad! I'm still going thru the stacks of ICMJ I was givin (1959-1999,alot of reading!!). If I come across it I'll let you know. Meanwhile I'm putting my efforts into designing and building an Induced Polarization set, as it's the latest and most accurate method used by the Geophysicists for detection of various kinds of ore using the fall time of the return pulse (Gold is around 15 miliseconds or so). Yep, with a 555 and a 100 watt 12volt car stereo amp., you could pump some serious current into the earth. For the receiver, a simple pickup loop into a opamp chain
    will do nicely. It's worth putting rods into the earth, knowing your efforts will be rewarded!
    Randy Seden
    Simi Valley, Ca.
    Re: VLF Detector Depth Enhancement
    July 19th,1999
    Rick,
    Randy Seden
    Simi Valley, Ca.
      July 19th,1999
      Rick,
      Randy Seden
      Simi Valley, Ca.
        July 19th,1999
        Rick,
        Randy Seden
        Simi Valley, Ca.
          Randy, I've did some experiments with VLF injection a while back. The detector makes really weird sounds, but the short of it is no depth enhancement. Probably hurt depth as it might have shifted the detection threshold slightly.
          Would like to know more about IP if you have info.
          - Carl
            - Carl
              - Carl
                Yep, with a 555 and a 100 watt 12volt car stereo amp., you could pump some serious current into the earth. For the receiver, a simple pickup loop into a opamp chain[/i]
                ???---have not read any on this---but do know that
                if you dampen the soil to increase conductivity,
                (dry soil not too conductive and 1000 v to get currant) and inject
                60 hz at some 100-200 volts---rods some 10 feet
                apart you can get earth worms to come up in a
                very large number-----at least in ohio---
                rick
                  rick
                    rick
                      [email protected]
                      103 North Sixth Avenue
                      Virginia, MN 55792 USACOIL INFORMATION - Generally speaking
                      refers to Tesla Coils
                      which is obviously a different application. Nevertheless, in my
                      opinion anything that is good
                      for a Tesla Coil should be MORE THAN good enough for our proposed
                      application. Obviously
                      much of the stuff included will be superfluous so I would appreciate
                      any comments from
                      those more knowledgeable than me. Most of this excerpted from
                      various Tesla Coil
                      sites. There is much duplication on these sites so it is very hard
                      to assign
                      credit or responsibility for many statements.
                      The coil form should be a low loss material (we are talking about
                      radio frequency
                      losses in the 50 - 1000 kHz range) like polyethylene, polystyrene,
                      or polypro-
                      pylene, polycarbonate (Lexan), acrylic (Plexiglass), or even ABS or
                      PVC.
                      The coil form must be free of major surface imperfections. I wet
                      sand my coil
                      forms with #150 wet/dry sandpaper (or emery cloth) and water to
                      remove markings,
                      oxidation, scratches and cuts. After wet sanding, the coil form must
                      be dried
                      thoroughly. If PVC plastic is used the coil form should be dried in
                      a drying box,
                      gently baked under a heat lamp, or even placed in a very low
                      temperature oven for
                      a few days. PVC coil forms must then be sealed to negate the high RF
                      loss factors
                      that are inherent to this plastic. Sealing also prevents PVC
                      plastic from reab-
                      sorbing moisture. Using a sealer such as petroleum based
                      polyurethane varnish,
                      two-part clear epoxy paint, or some acrylic spray sealers is
                      important. Avoid wa-
                      ter based and milky "emulsion" type sealers.
                      If drips and sags do occur, then can be "grated" off with a body
                      putty grater, or
                      carefully trimmed away with a knife while the sealant is still
                      pliable.
                      The coil should be close wound with a good quality magnet wire. I
                      use double Form-
                      var enamel coated magnet wire purchased surplus, but newer
                      insulations such as
                      Polyimide coatings are even better. Magnet wire gives the maximum
                      inductance per
                      unit volume of coil form.
                      Q. How would someone go about drying a PVC or similarly hygroscopic
                      material be-
                      fore it was to be sealed? In the oven? What temperature? Is the
                      interior of the
                      form sealed as well?
                      A. Before I get to the drying stage, I go ahead and wet sand the
                      coil form with
                      abrasive paper or emery cloth. I use a #150 grade of abrasive and
                      sand with water
                      until all printing, oxidation, and major dings (cuts and scratches)
                      are removed.
                      One of the best ways to dry this plastic is to get a large cardboard
                      box. Cut a
                      few small vent holes in the top and bottom of the box. Thread some
                      string or
                      light cord through the top of the box to form a sling to hold the
                      coil form. You
                      will need two or three loops of cord inside the box to securely
                      suspend the coil
                      form near the top vent holes. Place a light bulb on a heat resistant
                      insulator in-
                      side the box directly below the coil form. Depending on the ambient
                      temperature,
                      the size of the box, and the number of vent holes, the wattage (or
                      number) of
                      bulbs may be varied. The heat from the bulb(s) will produce a warm
                      air convection
                      inside of the box that will effectively dry the coil form over a
                      period of no
                      more than three days. The temperature does not need to be very high,
                      temperatures
                      between 120 - 150 degrees F are just fine.
                      Once removed from the drying box, the outside of the coil form
                      should be sealed
                      immediately, then wound with wire. Once the coil form is wound, the
                      ends of the
                      coil form are capped with plastic disks glued down with epoxy to
                      form a hermetic
                      seal. However, if the coil form is removed from the drying box and
                      winding is de-
                      layed for some reason, one coat of sealer should be applied to the
                      inside of the
                      coil form to prevent moisture from reabsorbing. If the winding
                      proceeds at an or-
                      derly pace without delays, then the end caps will prevent air
                      exchanges which re-
                      moves the need to seal the inside surface of the coil form.
                      Q. Besides polyurethane what is a good sealer for a secondary coil
                      form and where
                      do I get this sealer?
                      A. The coating that I used is called Super Gloss Build 50 by Behr.
                      I got it at the hardware store. (Hugh M. Woods, aka Payless
                      Cashways) It is in two
                      paint cans, shrink wrapped together. The can wrappers are orange.
                      The stuff is
                      stocked in the varnish section, right next to the polyurethane. The
                      potential
                      problems are bubbles, which didn't seem to make much of a
                      difference for me, and
                      annular bulges. The bulges appear if you don't get the coating on
                      evenly and the
                      form is turning. I would not recommend using Build 50 as a coating
                      unless you feel
                      confident in your abilities to apply it smoothly and evenly. I
                      ended up with some
                      bulging, but it doesn't detract from the over all appearance. It
                      would however
                      cause problems if one used it to seal a PVC pipe under the winding.
                      This would
                      make the windings irregular and probably cause the top coat to be
                      very uneven as
                      the stuff bulges and climb towards the high spots as the form turns.
                      Neverthe-
                      less, I still recommend Build 50 since it goes on in one coat and
                      is quite tough
                      and hard. Chip Atkinson
                      Q. And what about using a Silicon RTV type cement to attach the
                      ends. This stuff
                      is definitely non-flamable and is hard to screw-up with.
                      A. Good Question! Sounds great does it not..? But... These adhesives
                      leave a re-
                      sidual acetic acid vapor which is trapped in the coil form. The
                      acetic acid vapor
                      is highly conductive and ionizes readily. DO NOT USE THESE PRODUCTS
                      in this par-
                      ticular application.
                      Importing text written by Steve Crawshaw:
                      I've just intercepted RQ's request for info on secondary coatings,
                      and I thought
                      I'd throw my info in here. In UK there is a component distributor
                      called RS Com-
                      ponents who supply all sorts of electronics gear. They have a number
                      of products
                      for HV insulation. I have got hold of a tin of the following Anti
                      Corona Lacquer
                      569-290 $2.86 400ml Aerosol. This has a dielectric strength of
                      48Kv/mm with a
                      working temperature of up to 150 degrees C.
                      BTW, the reason I have recommended that solvent based adhesives NOT
                      be used when
                      capping the coil form is because the explosive vapors are trapped
                      inside of the
                      coil. If points #1-3 are followed then point #4 should not be too
                      critical, but if
                      an internal failure of the secondary coil does occur, you can count
                      on any
                      trapped vapors igniting and an explosion will result. This is not
                      just an idle
                      warning either. I have had it happen and it was nothing but dumb
                      luck that a seri-
                      ous accident did not result.
                      Q. Quoting Ed H: On the subject of coatings:> Richard Hull (or
                      TCBOR) mentions in
                      the guide to the Colorado Springs notes that he/they don't use
                      secondary coatings
                      anymore - or at least they were using only a single thin coat. He
                      says they avoid
                      breakdown from the coil by proper terminal placement. Any comments
                      on Hull's
                      method?
                      A. Yes, Hull's method works just fine. Many times I have test fired
                      a coil with no
                      coating whatsoever. While coating is not an absolute necessity, it
                      is worthwhile
                      for several reasons. Coatings prevent the winding from loosening and
                      slipping off
                      the coil form. Coatings decrease the chances of a coil suffering
                      permanent dam-
                      age as a result of over-coupling and "splitting". Coatings provide
                      physical pro-
                      tection to the winding and help prevent serious damage to a coil
                      that may result
                      from bumps, dings, cuts, falls, etc. During experimentation a
                      coiler may choose
                      to deliberately over-drive the coil, the coil may be overdriven
                      accidently, or
                      the coil may be fired in unusual configurations where the electrical
                      stress may be
                      high (Tesla Magnifier and bi-polar configurations for example). The
                      coating does
                      reduce corona losses and reduces the incidents of electrical
                      breakdowns. A well
                      applied coating looks good, and can be maintained. I guess the
                      argument here is
                      that if you are winding a coil to become part of a permanent system
                      where changes
                      are rarely or infrequently made (like a museum or display coil) one
                      or two light
                      coats of sealant, or just enough to stick the windings down, would
                      be fine. Once
                      tuned and adjusted with a proper toroid the coil will function well,
                      and without
                      excessive corona losses. But on the other hand if you are like me;
                      a person who
                      frequently removes/replaces/stores coils, changes primary
                      configurations, gaps,
                      caps, dischargers, fires an occasional Magnifier or bipolar system,
                      etc.. The ben-
                      efits of a good heavy coating are clear, if for no other reason
                      than protecting
                      the winding from accidental physical abuse.
                      I have found that the benefits of a heavy coating on the secondary
                      far outweigh
                      the advantages of a light or nonexistent coating. Also, there are a
                      lot of begin-
                      ners out there. Beginners especially need the physical and
                      electrical ruggedness
                      that a heavy coating provides.
                      Text file for COILBLD2.GIF, graphical instructions for construction
                      of high per-
                      formance 1/4 wave Tesla resonators.
                      Once the coil is wound, it is sealed to prevent corona leakage and
                      to help protect
                      against electrical breakdown between turns. Sealing also prevents
                      the windings
                      from loosening up on the coil form. I use the same sealers mentioned
                      earlier,
                      those being petroleum based polyurethane, two-part clear epoxy
                      paint, or water
                      free acrylic. Coats of sealer are applied with a brush or spray
                      until there are
                      no ridges and valleys in the wire. In other words the coats must
                      build up until
                      the wire is completely imbedded in sealer. A fan and radiant heat
                      source may be
                      used as required to speed the cure rate of the sealer. Rotating the
                      coil on the
                      winding spindle will aid in obtaining a smooth coating that is free
                      of runs and
                      drips.
                      Polymide - This insulation has the best high temperature
                      properties of
                      all wire enamels developed to date. Its burnout,
                      heat shock, and thermoplastic flow resistance far excels
                      that of all
                      other enamels.
                      From Chip - Build Super Gloss. Purpose: Interior decoupage & super
                      laminate.
                      Made by Behr Process Corp. Santa Ana 92704. The stuff's for
                      laminating things
                      such as bar tops, table tops, etc. It's basically two part epoxy.
                      It smells like
                      epoxy and cures like it. It smells like epoxy and cures like it
                      too. It's clear
                      as water. There is no solvent base, but you can clean it up with
                      acetone. There
                      is a hazard label which says causes severe eye and skin burns.
                      NEW. I have coated two secondary coils with Polyurethane coatings
                      in the last 20
                      months with good result. I should really qualify that remark "good
                      results". My
                      goal was to provide a means of locking the wire onto the form, make
                      the entire as-
                      sembly moisture proof and also create a high gloss finish simply to
                      improve the
                      appearance. I never spend any time check on any improvement in the
                      overall coil
                      dielectric properties.
                      I would strongly recommend NOT using WATER-BASED polyurethanes, this
                      stuff is crap
                      IMHO. Go with the clear gloss oil-based stuff. I prefer Behr for
                      its super fast
                      drying times, and I have the new low VOC Minwax stuff - it takes WAY
                      too long to
                      dry. Also I am curious if anyone has used Behr's Build 50; this is
                      the thick ep-
                      oxy coating that is used to make those tacky bar tops with the old
                      coins in
                      them... It is supposed to be as thick as 50 coats of urethane, but
                      it's also de-
                      signed to be applied to any flat horizontal surfaces, to prevent
                      running and pool-
                      ing, so I have my doubts about getting it to work on a cylindrical
                      coil. ADAM.
                      NEW. I'm puzzled about the cracking comment too. It probably
                      depends on the par-
                      ticular brand of polyurethane, but I've had excellent results from
                      the good old
                      "Behr Super Build 50" product. This last February I ran a test of
                      sorts on the
                      sample of the 22.75" diameter HDPE form I will be using as my #5
                      coil form. I
                      coated it with the Behr Super Build 50 and let it dry for 3 days.
                      They cylinder
                      had the top and bottom cut off so when I stepped on it to deform it,
                      it bent in a
                      very severe manner. The polyurethane product did not suffer at all
                      - absolutely
                      no cracks or separation was found from the form itself. This was
                      then repeated
                      about ten days later, again with good results. Id did wipe down the
                      form with
                      XYLENE to make sure it was clean prior to coating it, if that is of
                      any interest.
                      My coil form from 2 years ago still looks brand new with the same
                      product. (When
                      I sued my circular saw to section the form for recycling, the poly
                      coating did
                      fail.) Chuck Curran.
                      NEW. I have several coils that I wound over 20 years ago and coated
                      with polyure-
                      thane and they are as good and as nice looking as the day they were
                      dried. The
                      alternatives you mentioned; G.E. Glyptal and Dolph's AC-43 air dry
                      varnish, are
                      needlessly expensive when compared to either polyethylene, shellac
                      of varnish, all
                      of which work quite well. BTW there may be differences in
                      polyurethane finishes,
                      I used Zar brand, clear glossy, oil based. Alfred A. Skrocki.
                      My notes show - Use petroleum based polyurethane varnish. Prevents
                      PVC plastic
                      from reabsorbing moisture. Avoid water bases and milky substances.
                      - das.
                        MANAGER
                        Quote for AC43 Varnish Air dry
