Magnetic anomalies etc.
  • Magnetic anomalies etc.
    Roger,
    My consulting company recently looked at various fluxgate magnetometer
    sensors with the specific goal of coming up with a cost-reduced design for
    the sensor itself. The attached file describes plans for a family of such
    inexpensive flux-gate sensors. So, if you are inclined to build things
    yourself, I believe the attached file will help you build the sensor
    itself. If you are wish to go further and build a gradiometer using two
    such fluxgates, I can send you the schematic; please read the attached file
    for more information.
    I also have a suggestion for increasing the probability of detecting
    underground ferromagnetic objects. As you know, most ferromagnetic
    substances do not sufficiently disturb the ambient field for reliable
    detection under all circumstances. The idea is to magnetize them before
    detection, so that they can be detected by their own field, rather than by
    their redirection of the ambient field. Therefore, you zap the test area
    with a strong magnetic field and then you scan it with a magnetometer in
    the hope that the target has been magnetized and has a field of its own.
    Obviously, you DO NOT do this in an area containing land mines or other
    electronics, but the inducing field can be generated by something as simple
    as a large coil of wire momentarily connected to a car battery.
    This method is more suitable for finding archeological artifacts
    ("treasure"), than for what you have in mind, but perhaps other members of
    this mailing list have done it, and can offer advice on how best to use it.
    Sincerely,
    Peter Vizmuller
    President,
    RHR Laboratories
    www.rhrlaboratories.com
    Fluxgate.pdf
