making housing for Geometrics G-856 proton sensor for underwater use
  • making housing for Geometrics G-856 proton sensor for underwater use
    I have acquired a used Geometrics G-856 Proton Mag. These have been made for 31 years and the new version G-857 just adds a GPS logging function. I am looking to see if I can use this sensor underwater if it is enclosed in a properly built tow fish housing? I can machine out of plastic a housing, but don't know if anything special needs to be done? The sensor has a North arrow marked on it, so if I am running a survey, how do I compensate for the sensor facing 180 degrees from the original north facing direction when I start the first survey line?
    You just have to keep the north pointing arrow either pointing north or south during your survey to get maximum signal.
      Thanks! So it sounds like if I run my survey grid east-west, with the arrow on the probe facing either north or south, that would be fine. I was under the impression the arrow on the probe always needed to be facing north. If it works just as well facing south, then that would be great! I can layout my grid then very easy on a west-east basis. Any idea how far off the bottom the probe could be for proper operation? I assume the bigger the target, the higher the probe can be, but wondered if there is a standard depth above the bottom used? Any tow fish designs available anywhere to build from scratch?
