PROTON RICH SUBSTANCES REVIEWED & SOME UNANSWERED QUESTIONS
  • PROTON RICH SUBSTANCES REVIEWED & SOME UNANSWERED QUESTIONS
    Some considerations for proton rich substances: The proton bearing
    liquid must
    have a high composition of hydrogen atoms and its relaxation time
    should be such
    that the signal to noise ratio is large enough at the end of the
    measurement pe-
    riod; but not too long or the polarization time would be
    inconveniently long. The
    proton liquid must be able to withstand adverse conditions ... 60 C
    to -20 C...
    If the liquid is frozen, NOT ONLY IS THE SIGNAL LOST, but the
    resulting expansion
    may burst the encapsulation. ... Methyl alcohol best compromise...
    or .... (See
    Posting # 8.
    Why is the signal lost when the liquid turns to a solid? It will
    still have the
    same number of Hydrogen atoms!
    Does this mean that if for example, solid paraffin is suitable in
    all other re-
    spects, that it will NOT work because it is a solid?
    Substance Formula Mol-Wt #Hats S.G. Chi.
    Benzene C6H6 78 6 876.5
    .607
    Dekalin
    Ethanol C2H6O 46 6 789.3
    .927
    Heptane
    IsopropanolC3H80 60 8 780.9 .937
    Kerosene H2O2? 34? 2? 810.0
    Methanol CH4O 32 4 791.4
    .890
    Meth/Water*
    Paraffin 19? 2? 900.0?
    Pentane
    TEMPONE
    Water H2O 18 2 1000.0?
    1.000?
    "Chi." is the constant that tells us how sensitive the proton rich
    substance
    is.(JAK - Posting # 90) PRESUMABLY, distilled water, with no
    dissolved oxygen,
    has a rating of 1.00.
    *Meth/Water was selected by one knowledgeable researcher. It
    consists of dis-
    tilled water and 20% methyl Alcohol along with ferric nitrate in the
    amount of 10
    to the -17 gm mols per liter. This solution is four times faster
    than pure methyl
    alcohol. (See Posting # 88.)
    Basically the table is taken from Jim Koehler's manuscript with some
    possibles
    added and a tiny bit of information added. Unknown to me was the
    fact that Etha-
    nol and Ethyl Alcohol are the "same" thing. Same thing for
    Methanol, but this is
    complicated by the fact that for some of the above items I have now
    found as many
    as 3 or 4 different formulas. Any help on this table will be
    GREATLY appreciated.
    Some additional considerations regarding proton rich substances;
    magnet wire and
    liquid filled coil forms:
    From Posting # 91. Very great care must be taken in both choosing
    construction
    materials and avoiding accidental ferro-magnetic contamination. An
    invisible iron
    filing will cause the signal decay TO BE REDUCED BY A FACTOR OF TWO
    OR MORE. The
    winding wire should be as pure as possible. Undoubtedly the failure
    of some coils
    is due to the few parts per million of iron in the copper
    wire....metal inclusions
    can occur in plastic piping... ...particularly true of recycled
    plastics. It is
    also possible that coloring materials used in the plastic contains
    iron minerals
    which will degrade performance.
    How can we check for this? Would one of the small $200 - $300
    Gaussmeters work
    for either or both of the above problems?
    Posting # 91 continued. Free oxygen in solution is paramagnetic:
    free nitrogen
    is not. Dissolved Oxygen... Some sensor coil forms e.g. POLYTHENE
    (sic?) are po-
    rous to oxygen and the liquid will again slowly take up oxygen from
    the atmosphere
    so that after about 7 days the signal decay has shortened again.
    Is it really "polyethylene" in the above quote or is there a
    "POLYTHENE" that I am
    not aware of? Can we not coat these inferior plastics with some
    impermeable sub-
    stance?
    For most of the items above, I am working with things I know little
    or nothing
    about. Therefore there will be typographical and other errors.
    Confirmation of
    any detail, however minor it may appear, corrections and additions
    will be greatly
    appreciated. For "bits & pieces" you may wish to E-me off forum to
    avoid clogging
    up the forum with seemingly unrelated "one liners". I will update
    the document
    and repost based on the new information. My address is
    [email protected].
    Best to all.
    Dale
