Eric, et al - EFFECT OF FREEZING ON PROTON RICH FLUIDS???
  • Eric, et al - EFFECT OF FREEZING ON PROTON RICH FLUIDS???
    If the liquid is frozen, NOT ONLY IS THE SIGNAL LOST, but the
    resulting expansion
    may burst the encapsulation. ... Methyl alcohol best compromise...
    or .... (See
    Protonmagforum Posting # 8.
    Why is the signal lost when the liquid turns to a solid? It will
    still have the
    same number of Hydrogen atoms!
    Roger speculates that this might be because the Hydrogen atoms are
    not as free to
    vibrate when frozen.
    From an old encyclopedia the following: "According to this theory,
    the molecules
    of water, which in the liquid form have considerable movement, have
    to occupy
    definite relative positions when the water assumes the form of ice.
    When pure
    water is cooled to 0 C., the energy of the molecules is sufficiently
    diminished to
    allow attractive forces to come into play under which the molecules
    assume the
    positions required for freezing but the presence of salt ...
    hinders...
    But paraffin contracts when freezing, so maybe different (maybe
    even worse)
    than water???
    Does this mean that if, for example: even if solid paraffin is
    suitable in all
    other respects, that it will NOT work because it is a solid?
    To make a long story short - If solids must be excluded as a
    possible proton
    rich substance, I would like to know so I can exclude them from the
    search.
    Best regards to all.
    Dale
    [email protected]
    103 North Sixth Avenue
    Virginia, MN 55792 USA
