Lee Fraser, et al. - Re: Toroidal Coil Forms:
  • Lee Fraser, et al. - Re: Toroidal Coil Forms:
    Lee: Your answer below is clear, understood and agreed to by me as
    it seems logical.
    But, what if the toroid form is the 8" donut with 1/8" thick walls
    of polyethylyne (I think - but plastic for sure) filled with liquid,
    plugged with nylon plug and sealed with RTV caulking; and then the
    outside is wrapped with aluminimum foil.
    Is this the same since we have the metal outside or does the fact
    that the metal is separated from the liquid by the plastic change
    things?
    This is of course an attempt to beat the potential problem of
    permeability of polyethylene.
    Thanks and best regards
    Dale
    No, a non-magnetic metal may not be used. The toroidal form would
    constitute the equivilant of a shorted ring in a transformer so any
    field changes inside it would be undetectable outside the toroid.
    Good question though.
