About FLC100 component
  • About FLC100 component
    I have schematic for flc100 and find to need a component which is left buttom side.
    CV 80 smd x4, can someone know this ?
    Dual diodes???
      Dual diodes???
      for example ?
        Maybe something like
        BAV99
        BAT54
        Do you have this circuit to measure?
        If so then a DMM is DIODE scale will tell you if this is diodes or not.
          https://www.picproje.org/index.php?topic=75827.0
          Cv80 smd 4x olarak kodlanmış ama araştırınca sot143 kasa ?ıkıyor. Yerine bat54c-s kasaları kullanılıyor diye biliyorum. Ancak bat54c-s kasalarından diyot birisini k?pr? diyot , diğeri ise ters d?z bağlayabiliyoruz. Şemaya g?re nasıl kullanılacak bu malzeme ?
            BAV99
            BAT54
            look also a version this is optocoupler and in DIP4. not smd then. sch does not view that CV80 is sure smd.
            PS. oops. this is smd. pcb https://redshiftlabs.com.au/product/...ensor-flc-100/
              thank you.Its clear looking
              Its 2264 11FH4 what is this ?
                https://e-magnetica.pl/_media/fluxga...322&tok=42d720
                C8J
                  Thank you, but when I type it to google, I dont see any component.
                      tantalum capacitors. 226A - 226 - 22 000 000 pf - 22 uF
                      A is voltage, 10 V
                        Thank you very much.
                          [ATTACH]58079[/ATTACH]
                          Thank you very much. Did someone made this ?
                          how did you wind coil, or any idea ? Because its to diffucult. 1 Mh and I think 550-600 turn from 15mm wire
                            Otherwise, why would someone draw a seed for nothing? Did you ask yourself?
                            If you don't have a good core, don't even try!
                              THANK YOU BROTHER
