S.A. magnetic field, AQUASCAN, toroids, proton fluid, GPS,
  • S.A. magnetic field, AQUASCAN, toroids, proton fluid, GPS,
    dGPS, etc.
    A few thoughts from George Davidson of South Africa (ZA).
    South Africa has an extremely low magnetic field of about 26,000 nT
    which means
    that most commercial mags do NOT work here because;
    a) the original Geometrics global map placed us at 29,000 nT and
    mags were tuned
    to that; and
    b) precession time is so short that after 300 mS the mags count
    noise. Normally
    average noise on good systems is +/- 5 nT even when running
    east-west, which makes
    it impossible to find a cannon that weight a ton at 10 metres (33
    ft. approx).
    AQUASCAN (UK) mags do work well but only after we redesigned the
    timing system and
    filled the probe with JET A1 as water never worked. The Jet A1 is
    used for tur-
    bine choppers here and is not as volatile whereas the aviation fuel
    we tried pre-
    vious was VERY volatile and when it leaked it dissolved glues and
    silicone seal-
    ants. [Jet A1 is the same as Jet A except for the addition of low
    temperature
    additives. When discussing the various jet fuels all values are
    NOMINAL unless
    you are dealing with a SPECIFIC fuel from a SPECIFIC manufacturer.
    All are
    volatile although some are less volatile than others. Generally
    speaking do NOT
    consider jet fuels unless you really know what you are doing. Do
    NOT even look at
    JP-4 because it is the most dangerous of the bunch and in fact is
    being phased out
    of use in the U.S. Air Force, I assume at least partially for that
    reason. - das]
    I use SCHOTT laboratory glass bottles to hold the Jet A1 and then
    slide it into
    the solenoid, which in turn is slid into a PVC pipe and re-entrable
    dual component
    resin is poured in. Unfortunately this won't help for toroidal
    designs. Make
    sure that the resins used are pretested for any ferrous components
    because one I
    used once WAS magnetic. I think Scotch [This might be 3-M in North
    America. -
    das] makes proper resins but we use local stuff as it is cheaper.
    [George - Can you explain "re-enterable dual component resin" as I
    do not think we
    use that term in North America? It sounds like you can reuse it and
    maybe it is
    not so hard to unstick when you have to change fluid? - das]
    [George - I wonder what method you use to pretest!!! - das]
    Toroids do not seem to work very well here either, perhaps the angle
    of inclina-
    tion is too low. I am speak here of "round" toroid designs as
    generally discussed
    on this forum. The Geometrics toroid works well because its design
    is an elon-
    gated toroid of 15 milliHenry. Unfortunately it pulls 5 amps at 24
    volts which
    flattens most batteries, that you can carry on an inflatable, in
    less than a work
    day. [George - I think I disagree, but read Jim Koehler's section
    on batteries
    and then let me have your thoughts, please. - das]
    The AQUASCAN mag takes in GPS Lat/Lon data and echo sounder depth
    readings so that
    one can download the data to a personal computer and draw 3-D
    magnetic maps as a
    post processing exercise.
    We us dGPS [differential GPS] with a base station which averages its
    position over
    a 3 hour period and then knows exactly where it is. The GPS data is
    exchanged be-
    tween base and portable via a modem and VHF link using a sequence
    called RTCM that
    contains (I assume) the corrective data for the portable GPS at its
    current loca-
    tion after the base has received the current data from the portable.
    So far,
    NO-ONE will tell me how to generate an RTCM sequence as it is
    apparently propri-
    etary secret. With this method we get 5 to 10 meter accuracy.
    I have tried running 2 GPS units simultaneously and feeding BOTH
    outputs into the
    COM ports of a personal computer, and subtracting the difference but
    the error is
    as bad as a single unit, even with two IDENTICAL units. The GPS
    signal tends to
    wander around an oval with Lat/Lon doing sine waves of their own
    frequency carving
    out a Lissajous figure which crosses true position from time to
    time. [I have had
    other reports stating that repeatability of standard units in
    northern Europe
    sometimes has deviations of as much as 700 meters. - Data from
    North American
    locations in respect to the degree of repeatability would be greatly
    appreciated.
    das]
    However for ROUGH magging we have gotten excellent results from the
    model of the
    GARMIN which has software which corrects (in a way) the position,
    especially if
    you are doing long, straight lines. This software result is
    predicated on the as-
    sumption that you CANNOT suddenly be 10 meters to starboard or port
    of your previ-
    ously indicated position.
