PARAMAGNETIC QUALITIES OF FREE OXYGEN
  • PARAMAGNETIC QUALITIES OF FREE OXYGEN
    PARAMAGNETIC - "Having a magnetic permeability greater than unity."
    (From:
    DICTIONARY OF TECHNICAL TERMS FOR AEROSPACE USE)
    "In the 1840s Michael Faraday discovered that oxygen is attracted to
    a magnet.
    Almost a century later, in 1925, Robert Mulliken explained why
    oxygen is magnetic
    using the recently developed quantum theory. His analysis shows
    that molecular
    oxygen has two unpaired electrons in its lowest energy state."
    (From: http://www.bio-laser.org/singox.html)
    Free oxygen in solution is paramagnetic; free nitrogen is not.
    Disolved oxygen
    can be driven out of water by bubbling pure nitrogen through it for
    20 minutes or
    by boiling it. (See posting # 91)
    However it seems that with plastic toroidal forms water WILL
    reacquire free oxygen
    over a 7 to 14 day period. This is due to the permeability of most
    plastics, and I am told
    is explained by "Henry's Law" which is an equation that shows the
    relationship be-
    tween pressure and solubility of gases in liquids.
    The primary effect, for our purposes, of the reaquistion of free
    oxygen, is that
    the signal decay time is decreased. Jim Koehler's PPM design
    addresses this prob-
    lem because he measures the signal rapidly enough that decrease has
    no practical
    effect on the accuracy of the reading. This may be true of other
    units also.
    Nevertheless this still leaves us with the question of IF the
    decreased decay time
    is the ONLY effect of the paramagnetic qualities of the free oxygen.
    In other
    words - has the amplitude or quality of the signal also suffered
    some degradation
    because of the free oxygen contained in the proton rich fluid
    (distilled water in
    this case)?
    I understand that this sounds like nitpicking BUT MANY companies
    make paramagnetic
    oxygen analyzers and the units I have looked at cost in excess of
    US$5,000.00.
    Therefore somebody seems to think that the effects are significant.
    The aforemen-
    tioned units are for medical applications often in connection with
    magnetic
    resonance imaging (MRI).
    Hopefully someone that is qualified in chemistry, will consider
    these questiona and
    put forth some ideas on the subject.
    The one thing I have come up with so far is HINT that Temone MIGHT
    keep proton
    rich fluids from reacquiring free oxygen and this might be the
    reason that Geonics
    and others use it in their toroidal sensors. I PREVIOUSL assumed
    that Temone
    was used to make a proton rich fluid, whereas I NOW have the
    opinion that it is an
    ADDITIVE to the proton rich fluid that is used.
    Best to all,
    Dale
