Re: Bifilar windings
  • Re: Bifilar windings
    The Proton Mag Forum
    Don't discard the idea of capacitive discharge so readily. These days you
    can buy 50 Farads (!) in a couple of cubic inches for a few dollars. These
    capacitors hold energy well over 100 joules. I suspect they can definitely
    be considered for polarizing current.
    Peter Boetzkes
    ----Original Message Follows----
    Reply-To: "The Proton Mag Forum"
    Subject: Re: Bifilar windings
    Date: Fri, 19 May 2000 11:16:10 -0300
    1. The magnetic field is proportional to the current in the coil and the
    number of turns. The curent in a coil is determined by Ohm's law I=E/R. In
    this case I would suggest the higher the current the better. Also if you
    double the voltage and halve the current, as was suggested the power remains
    the same but apparently the resistance has doubled.
    2. The polarizing current should be applied for some multiple of the spin
    relaxation time (on the order of seconds). This more or less rules out
    capacitive discharge as a source of the polarization current.
    3. The detection time need not be very long. Under ideal conditions a
    phaselock loop can acquire and lock in a few tens of cycles and the actual
    frequency measurement done in a period on the order of a tenth of a second
    or less.
    The hardest things to deal with are noise and the high gain required to
    bring the signal to a usable level.
    Lee
    __________________________________________________ ____________________
