Re: BIFILAR WINDINGS - RECAP OF RECENT POSTINGS #s 226 thru
  • Re: BIFILAR WINDINGS - RECAP OF RECENT POSTINGS #s 226 thru
    #248
    Thanks for sending this Dale. Could someone please send me the
    diagram. For some reason I'm missing the first couple of posts in
    this series. Also, where is "Jim Koehler's Proton Precession
    Magnetometers" where the spreadsheet tables were found? Maybe this
    thread will make sense to me now.
    Thanks,
    Charles
    > The Proton Mag Forum[Consult the original if any questions because I could
    have made errors in transcription - das]
    > BIFILAR WINDINGS
    > POSTING #226.
    > When I was using the spreadsheet tables in Jim Koehler's "Proton Precession
    Magnetome-
    > ters") I noted that for any fixed size of fluid container; as the number of
    turns of
    > any given wire size increased the signal level increased because of the
    increased in-
    > ductance and coupling. At the same time the polarization current, of course,
    de-
    > creased because of the increased inductance and coupling. At the same time,
    the po-
    > larization current, decreased due to the increased resistance of the longer
    wire. I
    > also noted that for any given wire size if I could double the polarization
    current for
    > the same number of turns I would get a substantial increase in the signal to
    noise ra-
    > tio.
    > This can be simply accomplished by using bifilar windings. That is, two
    windings are
    > applied at the same time. The switching is a bit more complicated and
    requires 4 FORM
    > C contacts rated in excess of the expected forward and backward currents.
    The sche-
    > matic below shows the switching arrangement. Polarization current is applied
    to the
    > two windings in parallel thus halving the resistance of the sensor. This
    will double
    > the polarization current thus increasing precession probability. The net
    result is a
    > stronger signal and a much improved signal to noise ratio.
    > The two coils are then connected in series for the detection cycle giving the
    sensi-
    > tivity associated with the larger number of turns. Trifiliar and even more
    numerous
    > windings are possible but there is a practical limit.
    > (Diagram in the original is at this point.)
    > Take care with polarity. Lee Fraser.
