Re: tests for magnetic materials
  • Re: tests for magnetic materials
    Mag forum,
    Another angle:
    Am late on this discussion as I have been maggin in Mocambique
    and have returned without malaria, cholera or yellow fever.
    I have wound a number of coils mostly solenoids and found a
    simple test for magnetic buildup which may be useful, as follows:
    In the field, a magnetized solenoid will show a deviation if swung
    from E-W to W-E, at worst up to 5 nT . Couldnt find any effect
    of ferrous contaminated Cu wire and assumed it would cancel
    itself out within the wire**. Did get deviations when mag probes
    were rubbing against anchor chain in the bilges of the boat or
    dragged across a warehouse floor or deck of a steel survey vessel.
    The test system I used was a hollow solenoid into which a bottle
    could be placed for testing the various fluids and over which a
    PVC housing with various plastics could be tested . Ran it
    overnight at 2 A from 24v DC to get some serious polarization and
    tested it in the field on top of a 3 Metre wooden pole which could
    be rotated and the trace observed. Using a notebook and a
    PICOSCOPE oscilloscope a number of measurements of various
    type s could be obtained
    . After that one can use the least offensive of the various
    materials from the same stocks to build the final toroid etc.
    I like the idea of bifilar windings but always think of the field
    situation like what cable to use and where the earth will be .
    Cable is always a problem and stray voltages on a boat can realy
    become a character -building experience. In addition ,cables can
    be microphonic and change capacitance (pF) with wave action ...
    George
    **PS Quiz: a ferrous particle in the very centre of a current
    carrying copper wire will become polarized in which direction?
