Re: Chemical resistance of green fishing float toroidal
  • Re: Chemical resistance of green fishing float toroidal
    form.
    Hi Guys,
    Any ideas for a 'container' or a fish for the fishing float coil???
    My PVC coil is just under 7" in diameter and I am trying to come up
    with an idea for a fish. Unfortunately, the biggest PVC drain pipe
    at my local Home Depot is only 6". I was thinking of a small plastic
    pail but don't really care for that idea.
    Also, is it necessary to have both sensors in the water?? I was
    thinking it should be possible to keep one sensor on the boat to
    cancel the 'magnetic noise' since it is fairly uniform. It will make
    fish construction easier and, if I understand this thing right, the
    further apart we can get the sensors, the more sensitive the
    instrument will be. The only problem I could forsee is the proximity
    of the sensor to the boats engine causing a large offset in that
    sensor. I dont know if the sensors are linear but if they are, when
    the fish is deployed the microcontroller could easily 'null' the
    difference and everything should be fine. Any ideas???
    Duke
    A piece of this fishing float submerged in high octane, unleaded
    gasoline was reduced to MUSH in less than 30 days. I also have
    piece of this float in several other fluids and NO damage is
    easily visible after thirty days. I had ASSUMED that this float
    was made of polyethylene but I do NOT know. If anybody is
    knowlegeable about plastics - let me know and give me your address
    and I will send you a piece of the float.
