Re: Virus alert
  • Re: Virus alert
    --My mag. is to be used on land.
    If it is of any interest, I have a copy of the plans for a differential
    magnetometer from a 1960 vintage "Skin Diver" magazine. AS the saying goes
    'been there and did that -until I was washed into a barnicle covered rock off
    Plaos Verdes, Calif.A quick way to loose weight!
    It is a kinda sorta modernized version of the original English project.It
    was ment for above salt water use and has a couple hints on how to keep the
    thing running once it has been dampend with salt water ( Lots of WD-40!). It
    was copy righted, I guess it would be OK to scan it if you are interested.
    I built the stand-alone mag. to get an idea of what it will take to successfuly
    get the gradiometer going.
    GwBower
    On Tue, 26 Sep 2000 09:44:57 Charles Williamson wrote:
    >The Proton Mag Forum
    >George, will your mag be for land or water use ? Thanks for the virus
    >warning.
    >Charles, Oak Island, NC
    >----- Original Message -----
    >From: george bower
    >To: The Proton Mag Forum
    >Sent: Tuesday, September 26, 2000 10:24 AM
    >Subject: Re: Virus alert
    >> this virus has been spreading through my companies E-mail system for the
    >last month inspite of a intensive camplain to stop it. The latest McAfee
    >update will catch and remove it.
    >> For what it's worth, I have built the "stand alone magnetometer" as
    >designed by J Koehler and am working on a much simplifed toroid winder
    >"inspired" by my companies winder.If I can get it to work,I'll put it on the
    >forum.
    >> GwBower
    >> >I have today received an e-mail virus with the subject " Fw: Life stages
    >text", and an attachment Life stages.txt.shs. I am warning you as you are
    >in my address book, and although I have completely destroyed the offending
    >e-mail and there should be no risk to you, it is as well to be warned. If
    >you receive this mail, delete it and remove it from your "deleted items"
    >folder. If you don't use MS Outlook or Outlook Express you should not be
    >affected.
    >> >Cris.
    >> >_________________________________________________ _____________________
