Another toroidal sensor shape
  • Another toroidal sensor shape
    Hi everyone.
    I've recently been corresponding with a fellow in France who is
    interested in making a large toroidal sensor. We've been kicking
    ideas around and ha made some suggestions which got me thinking of
    another somewhat toroidal shape for a proton sensor which might even
    be better than a simple toroid. It is the shape shown in the
    attached file. It has all the advantages of the toroid - good noise
    rejection, insensitivity to orientation with respect to the magnetic
    field. However, it is also easy to make .... AND, it gives a higher
    S/N!
    You could make a core like this by using two different diameters
    of plastic tubing. Glue end plates on the two concentric sections
    of tubing (and cut out the centres of each end, of course) and you
    have it. I'm quite excited about this because I have done the
    theory for this shape and it looks like you can get very high S/N -
    much higher than for a simple toroid (one with circular
    cross-section) of the same radius. That is because S/N depends on
    the volume of the fluid and it will obviously be much higher for
    this shape than for a similarly sized toroid with circular
    cross-section.
    I am revising my spreadsheet to incorporate this shape and
    expect to have this done in a week or so. I'm on my way down to
    Arizona for the winter next week and will probably not get the
    revised version onto my Web site before I get there.
    Jim
    Jim Koehler
    RR2, Site 292, C56
    Courtenay, BC, V9N-5M9
    Canada
    Email: [email protected]
    cylinderical toroid.PDF
