Re: Another toroidal sensor shape
  • Re: Another toroidal sensor shape
    Hi Jim
    I like the idea of the toroid shape, and perhaps instead of trying to glue
    end"washers" on to a sawn pipe, you could have a rubber ( or suitable
    material) O-ring squeezed between the large and small tubes at each end, as
    per diagram ( its only 2 Kb )
    The bottom one could be inserted and sealed first, the cavity between the
    tubes filled with water ( or whatever ) to the brim, and the top ring pushed
    in with a piece of wire between the ring and the outer tube, to allow
    displaced liquid to escape. The wire could then be withdrawn and the top
    sealed.
    John
    Cavalier Electronics
    L'Agulhas
    South Africa
