I have had endless problems with our new scanner and have not been able to get
the article copied. If anyone has a scanner and would be willing to scan and
send the article, I will be glad to mail that person a copy of the article.
Sorry about he delay.
GwBower
On Thu, 28 Sep 2000 07:06:57 John Smith wrote:
>The Proton Mag Forum
>I would also appreciate a look
>John
>Cavalier Electronics
>L'Agulhas
>South Africa
>----- Original Message -----
>From: "DesertEagle"
>To: "The Proton Mag Forum"
>Sent: 28 September 2000 05:43
>Subject: Re: Virus alert
>> I would be interested as well.
>> Jimi
>> Thanks, I would appreciate a chance to see the article. I have a ML Dalton
>> two fish boat towed mag but am always interested in new tools.Have just
>had
>> the opportunity to try out my Dan's side scan sonar and was rather pleased
>> with the results. Hope to have my tow tec boat towed metal detector
>finished
>> by the weekend so I can try it out.
>> thanks again,
>> Charles
>> From: george bower
>> To: The Proton Mag Forum
>> Sent: Wednesday, September 27, 2000 9:15 PM
>> > --My mag. is to be used on land.
>> > If it is of any interest, I have a copy of the plans for a
>differential
>> magnetometer from a 1960 vintage "Skin Diver" magazine. AS the saying goes
>> 'been there and did that -until I was washed into a barnicle covered rock
>> off Plaos Verdes, Calif.A quick way to loose weight!
>> > It is a kinda sorta modernized version of the original English
>> project.It was ment for above salt water use and has a couple hints on how
>> to keep the thing running once it has been dampend with salt water ( Lots
>of
>> WD-40!). It was copy righted, I guess it would be OK to scan it if you are
>> interested.
>> > I built the stand-alone mag. to get an idea of what it will take to
>> successfuly get the gradiometer going.
>> > GwBower
>> > >George, will your mag be for land or water use ? Thanks for the virus
>> > >warning.
>> > >Charles, Oak Island, NC
>> > >From: george bower
>> > >Sent: Tuesday, September 26, 2000 10:24 AM
>> > >> this virus has been spreading through my companies E-mail system for
>> the
>> > >last month inspite of a intensive camplain to stop it. The latest
>McAfee
>> > >update will catch and remove it.
>> > >> For what it's worth, I have built the "stand alone magnetometer" as
>> > >designed by J Koehler and am working on a much simplifed toroid winder
>> > >"inspired" by my companies winder.If I can get it to work,I'll put it
>on
>> the
>> > >forum.
>> > >> GwBower
>> > >> >I have today received an e-mail virus with the subject " Fw: Life
>> stages
>> > >text", and an attachment Life stages.txt.shs. I am warning you as you
>> are
>> > >in my address book, and although I have completely destroyed the
>> offending
>> > >e-mail and there should be no risk to you, it is as well to be warned.
>If
>> > >you receive this mail, delete it and remove it from your "deleted
>items"
>> > >folder. If you don't use MS Outlook or Outlook Express you should not
>be
>> > >affected.
>> > >> >Cris.
>>________________________________________________ ______________________
GwBower
>John
>L'Agulhas
>South Africa
>From: "DesertEagle"
>> Jimi
>had
>finished
>> thanks again,
>> Charles
>> From: george bower
>differential
>of
>> interested.
>> > GwBower
>> > >warning.
>> > >From: george bower
>> the
>McAfee
>on
>> the
>> > >forum.
>> > >> GwBower
>> stages
>> are
>> offending
>If
>items"
>be
>> > >affected.
>> > >> >Cris.
