Re: Problem using toroid
  • Re: Problem using toroid
    Hi Peter
    The 800mA excitation current turning off through a 15mH inductor is
    sure to ring at some frequency dependant on spurious capacitance.
    What is the frequency of the 100mS signal you get ? If it is way
    off the expected precession frequency expected at you location,
    then you have to dampen this signal without killing the wanted one..
    I shelved my unit at this same point as you have reached until I
    get some time to experiment :-)
    Some thoughts are:-
    a diode limiting the ringing to 0.7v or so, but this will still
    dampen the wanted signal superimposed on the ringing when the diode
    is conducting.
    A filter to select the wanted mV level signal from the V level
    ringing.
    A notch filter at the ringing frequency feeding a low impedance
    load.
    Asking a schoolkid to write a DSP program to retrieve everything I
    need from digitising the signal :-)
    I wish all in the group a happy holiday season, ( as you might have
    guessed , we have just returned from our staff Xmas lunch )
    John Smith
    Cavalier Electronics
    L'Agulhas
    South Africa
    ----- Original Message -----
    To: [email protected]
    Sent: 15 December 2000 15:31
    Subject: Problem using toroid
    The Proton Mag Forum
    Hi guys out there!
    I build a toroid made of 8pcs PVC waterpipes with 45° angle each
    for a PPM.
    The toroid has an outer diameter of about 3/4" (18 cm) and its
    body, where the coil is winded on, is about
    1 3/4" (40mm) thick. The 8 parts have been glued together using
    silicone, inside there is about 500ml
    (16 fl oz) destilled water which normally is used for filling car
    batteries.
    I used AWG #24 wire (0.5mm) and turned 6 layers on the toroid
    (about 7.5 feet (230m) wire lenght).
    It has a resistance of 15.2 Ohms and an inductivity of 14.7 mH. As
    I tried to get a signal out of the coil
    I "charged"´it with about 800mA current but got only a short
    output signal (about 100mS on my memory scope)
    which seems to be only a switching "ping" from the filters.
    Because of the very short signal I'm afraid that I did something
    wrong on the toroid. Can anybody tell me
    what went wrong? The electronics has be tested with a signal
    generator and scope and it works fine.
    Is this short "ping" which startes with a big amplitude and
    continuesly run down within 100mS possibly
    the signal of the protons? I think its much too short, also if I
    increase the charging current to 1.5A
    the signal becomes bigger in amplitude but not longer.
    Is it possibly a problem if some acetic acid is left in the toroid
    coming from the silicone glue?
    After each layer I winded some double sided duct tape around the
    toroid for fixing the wire, is this
    possibly a problem?
    Thanks for telling me your experiences! Please mail me at
    [email protected]
    Best greatings from germany
    Peter
